Pocket GPS World :: View topic - nuvi2340 Touch screen not sensitive enough.
adiegreen
PostPosted: Sun Jun 12, 2011 8:41 pm    Post subject: nuvi2340 Touch screen not sensitive enough. Reply with quote
The touch screen on the 2340 when in the browse map mode is almost impossible. I have to give mine a real knock with my finger nail to get any sense out of it. It takes 2-3 times before it responds which will not do the screen any good .
I live on Anglesey North Wales, i am often trying to locate a remote lane or even a field corner. Unless there is actually an item on the map the touch screen will not respond. I could do this on the 250
I am alone is this a fault or just the norm?
I am not dissapointed with the 2340 it has some good features but sometimes lacks the finesse of my old 250.
adiegreen
PostPosted: Sun Jun 12, 2011 8:54 pm    Post subject: RE callibrate the touch screen Reply with quote
ha haa. Sorted it Use the following to reset the pressure.......
To calibrate the touchscreen on a nuvi 2200, 2300, or 2400 series device, please follow the instructions below:
Make sure the nuvi is turned off.
Press and hold the top left corner of the touchscreen.
Power the unit on while applying pressure on the top left corner.
Continue applying pressure to the top left of the screen.
After about 30 seconds a small dot will appear on a white screen.
Release the touchscreen and accurately touch the dots as they appear. (The dots will change location as touched.)
Once complete, a message will appear that says 'Calibrate Complete'
Touch OK
22.051 (01 May 24)
