Pocket GPS World :: View topic - Heat reflective windscreens - Vauxhall vectra
scoobydoo_uk
PostPosted: Tue Jun 01, 2004 10:51 pm    Post subject: Heat reflective windscreens - Vauxhall vectra Reply with quote
Im looking at purchasing a GlobalSat: BC-307 Compact Flash GPS Receiver to use as a SATNAV system along with my IPAQ 2210 and TOMTOM navigator 3.
Ive got a Vauxhall Vectra model c (2003 registration) which I believe has got a heat reflective windscreen.
I was wondering, will this have any major effect on this GPS device?, will it work ok?.
lbendlin
PostPosted: Wed Jun 02, 2004 2:14 pm    Post subject: Reply with quote
oh yes. Especially if you plan to use a CF receiver. You will want to think about an external antenna with a MMCX connector so you can place the antenna in a spot behind the rearview mirror (which is normally not coated) or in one of the corners (ditto). Or you rethink and get a BT receiver that you can place arbitraily in the car, for example somewhere on the back. Even a serial receiver is better in that situation.
Lutz
TomTom/TeleAtlas NAVTEQ
22.053 (15 May 24)
