rockin_plumber Lifetime Member
Posted: Sat Jun 26, 2010 8:29 am Post subject: V855 Postcodes released (see first post) (UPDATED 11/09/10) |
Direct download link from TomTom
http://www.tomtom.com/updates/zipcodes/Map_855/zip.zip
Edit to change post to sticky - Mike Alder
Last edited by rockin_plumber on Sat Sep 11, 2010 7:38 am; edited 1 time in total |
AliOnHols Pocket GPS Verifier
Posted: Sat Jun 26, 2010 10:55 am Post subject: |
many thanks rockin_plumber. _________________ Garmin Nuvi 2599
SatMap Active 10 & 20. |
Guivre46 Frequent Visitor
Joined: Apr 14, 2010 Posts: 1262 Location: West London
Posted: Sat Jun 26, 2010 11:14 am Post subject: |
Thanks. Not expecting much change from 845 _________________ Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom |
Posted: Sat Jun 26, 2010 11:28 am Post subject: |
Guivre46 wrote: | Thanks. Not expecting much change from 845 |
The UK Postcodes are a WHOLE 8KB larger file size |
Posted: Sat Jun 26, 2010 10:18 pm Post subject: |
Whew - need a bigger sd card..... _________________ Mike R [aka Wyvern46]
M8TJT The Other Tired Old Man
Posted: Sat Jun 26, 2010 10:30 pm Post subject: |
rockin_plumber wrote: | Guivre46 wrote: | Thanks. Not expecting much change from 845 |
The UK Postcodes are a WHOLE 8KB larger file size | Well, how many extra postcodes have been issued since then? 8Ks worth by the sound of it |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15138 Location: Bradford, West Yorkshire
Posted: Sat Jun 26, 2010 11:26 pm Post subject: |
well, if a post code is 8bytes (7 characters plus space: XX99 9XX) that means it has roughly 1000 new postcodes. i may be wrong though as this assumes the data is stored as 'plain text' which i doubt.
MaFt |
hazzamon Occasional Visitor
Posted: Sun Jun 27, 2010 3:34 am Post subject: |
MaFt wrote: | well, if a post code is 8bytes (7 characters plus space: XX99 9XX) that means it has roughly 1000 new postcodes. i may be wrong though as this assumes the data is stored as 'plain text' which i doubt.
MaFt |
It won't just have the postcode stored, but also the geographical location of each postcode. So it could just be a few hundred new post codes in the file. |
Posted: Sun Jun 27, 2010 9:29 am Post subject: |
Certainly not enough to have solved the 'long roads with several postcodes' problem. _________________ Mike R [aka Wyvern46]
matthewj Frequent Visitor
Posted: Mon Jun 28, 2010 10:14 am Post subject: |
Can I ask a silly question? If I use the map update facility (when they get it fixed), does this get installed automatically, or do I actually need to do this post code file manually? Could someone explain the background info please? Thanks! Matthew |
GerryC Pocket GPS Moderator
Posted: Mon Jun 28, 2010 10:47 am Post subject: |
Not a silly question at all Matthew. You would expect the postcode file to be included in a map update but they hardly ever are (not sure if they have ever been).
Recently, the files appear to have been updated more regularly but in the past several map versions would be released with no update to the postcodes at all. Even now, it is still separate from the actual map.
The normal way to learn about new postcode files is from people on forums 'finding' the link at tomtom.com. _________________ Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount |
Posted: Mon Jun 28, 2010 4:20 pm Post subject: |
Thanks - will updated when the new maps are out then... |
idontspeed Lifetime Member
Posted: Tue Jun 29, 2010 8:28 pm Post subject: |
Will this new postcode data work on an old map version. I have 2 tomtoms (one new & an old for spare). My old unit is a TTone version2 with GB maps which are around 2 years old. If the new postcodes will install, does that mean the sat nav will be able to navigate to the location of that postcode but without the "new" roads being displayed. |
Andy_P Pocket GPS Moderator
Posted: Wed Jun 30, 2010 12:56 am Post subject: |
Interesting question!
I would be 99% confident the new postcodes will work with an old map, but hadn't considered the possibility of them pointing it to a place without roads.
Can you try it and see? So long as you have the old ones backed up you can't do any harm. |
keefy7 Occasional Visitor
Posted: Wed Jun 30, 2010 6:11 pm Post subject: Re: V850 Postcodes released if anyone is intersted |
zip (1).zip Tried this twice now. Keep getting corrupt file when opened with winrar. Now on my third attempt of downloading a non corrupt file
third time lucky |
