Pocket GPS World :: View topic - Down loads (Garmin-Do they overwrite onld ones?)
toyota23
PostPosted: Sun Aug 01, 2010 11:10 am    Post subject: Down loads (Garmin-Do they overwrite onld ones?) Reply with quote
Hi all
When I download the updates for my garmin does it take the out of date info off the unit?
Cheers Toyota Question
PostPosted: Sun Aug 01, 2010 12:22 pm    Post subject: Reply with quote
When you use POILoader to upload POIs onto your Garmin, it replaces EVERYTHING that was on there before - old speed camera data AND any other POI files you had added.
Therefore, the method you should use is to collect any POI files you want (including the speed camera data) all into one folder on your PC.
Then you point POILoader to that folder and it will upload everything in one go.
When you get next week's new camera database, put it into the same folder on the PC with everything else (which will overwrite the old camera files) and then repeat the process of uploading everything all in one go with POILoader.
toyota23
PostPosted: Fri Aug 06, 2010 11:49 am    Post subject: loading new cameras Reply with quote
thank you for your information
regards Toyota
22.053 (15 May 24)
