Robin2 Lifetime Member
Posted: Thu May 27, 2004 3:53 pm Post subject: Reducing stored programs after install |
Having just installed TTN3 upgrade I notice that In the storage area I have TomTom Wizard. Am I correct in assuming that I can safely remove this now that TomTom 3 is running OK?
Also, I installed the update 3.01 from the web. During the setup process I was askd to repeat the setup to install the latest GPS driver. I now see that in the storage area I have 2 files
TomTom ~ GPS and
TomTom GPS
Obviously I don't need both - which should I delete? I have an iPAQ 2210 but am NOT using Bluetooth
BTW I bought a Fujifilm 256 MB SD card from Savastore for £37.50 (Japanese - TomTom3 works very well from this card) It was reduced from well over £100
Robin |
DavidW Pocket GPS Moderator
Posted: Thu May 27, 2004 4:40 pm Post subject: |
You can indeed get rid of TomTom Wizard - it serves little purpose other than wasting memory.
You will only have one copy of TomTom GPS installed - but as TomTom changed the device string declared to the application manager somewhere in the 2.x series, you get this issue. If you want to try to tidy up, you could try uninstalling "TomTom ~ GPS" (it will probably need uninstalling twice, most likely with a soft reset after each, which you will be asked to OK) then see if you can get rid of "TomTom GPS" afterwards (you may find this fails).
You'll then need to reinstall TomTom GPS!
David |
ttrevor Lifetime Member
Joined: Dec 04, 2003 Posts: 540 Location: Sleaford Lincolnshire UK
Posted: Thu May 27, 2004 4:56 pm Post subject: |
I has this when i installed TT3 ,i tried to get rid of TomTom~GPS but to no avail,when i did a soft reset GPS would not start so i replaced with a restore and left well alone,it runs ok ,let us know how you get on ,i would be most interested
cheers trevor _________________ Iphone x 64gb IOS 11.3.1 / IPhone 6 Plus 32gb IOS 12 beta /Volkswagen Scirocco R 280 bhp /Suzuki Vitara swb vvt+ /Suzuki Jimny special/running Apple Mac Mini / Apple air/ iPhone x /6 plus navigation / Apple car-play |
