JoolsTwo Regular Visitor
Posted: Tue Jun 22, 2010 10:04 pm Post subject: POI.DAT |
I got fed up with my inbuilt POIs getting in the way so renamed my POI.DAT to POI-X.DAT so that it's not recognised and I just see my custom POIs listed.
The trouble is I've started using the map correction "report" button to mark locations I want to modify later, and want to mark them as "add a missing POI", but now don't have any inbuilt POIs, so get a " No POI found" error message. Is it possible to make a new POI.dat file with just a dummy POI category so that I can mark the location then use TYRE to edit it later to the correct category. Any ideas?
Also is it possible to edit the report button icon to something a little less intrusive? _________________ TomTom ONE Series 30 (v8) & TMC traffic
App 8.010, UK & ROI Map v860.3126, TT Home 2.7.6.2056
andy-c1 Lifetime Member
Joined: Feb 05, 2005 Posts: 1039 Location: East Sussex
Posted: Tue Jun 22, 2010 11:15 pm Post subject: |
just make another poi category and when you want to make a correction just place the corrections in there _________________ TomTom 5001 |
GerryC Pocket GPS Moderator
Posted: Wed Jun 23, 2010 12:03 am Post subject: |
As you've found, without the poi.dat file, you can't add pois via mapshare as that's for internal pois and not 3rd party ones.
A way around is to start doing a change of road direction for example but don't save it. If you cancel out and go to "browse map", the cursor will be at the point selected and you can add points to your own files from there.
If you're going to use Tyre, you could just make a note of the co-ordinates from the bottom of the screen and type it into Tyre.
The icon design is built in so can't be changed. _________________ Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount |
pcaouolte Frequent Visitor
Joined: Dec 27, 2006 Posts: 998 Location: South Lincs, UK.
Posted: Wed Jun 23, 2010 1:08 pm Post subject: Re: POI.DAT |
JoolsTwo wrote: | ...I've started using the map correction "report" button to mark locations I want to modify later, and want to mark them as "add a missing POI", but now don't have any inbuilt POIs, so get a " No POI found" error message. Is it possible to make a new POI.dat file with just a dummy POI category so that I can mark the location then use TYRE to edit it later to the correct category. Any ideas? |
The categories in POI.DAT are fixed by the tomtom application. It is not possible to make a POI.DAT with a dummy category. It is, however, possible to make a POI.DAT with just one POI in one of the existing categories, or one POI in each of the existing categories, would either of these options serve your purpose? _________________ Paul |
Posted: Wed Jun 23, 2010 2:19 pm Post subject: Re: POI.DAT |
pcaouolte wrote: | It is, however, possible to make a POI.DAT with just one POI in one of the existing categories, or one POI in each of the existing categories, would either of these options serve your purpose? |
not sure, do you mean have a POI.dat with just one category, that would be fine
I have been experimenting and found an alternative way to do it. If you report a mobile speed camera, this saves the location to a OV2 file _________________ TomTom ONE Series 30 (v8) & TMC traffic
Posted: Wed Jun 23, 2010 7:33 pm Post subject: |
If you want to PM me your email address I'll send you a POI.DAT file that has just one dummy entry in the "Winery" category. _________________ Paul |
Posted: Fri Jun 25, 2010 9:49 am Post subject: |
many thanks Paul, it works a treat. The report mobile camera option was giving me problems as it sometimes caused the TT to reboot _________________ TomTom ONE Series 30 (v8) & TMC traffic
