mccririck Frequent Visitor
Posted: Mon Apr 19, 2010 9:12 pm Post subject: which speed camera icons to use with TTN7? |
I'm using TTN7 on a 3.5 inch screen, what are the best size speed camera icons to use? In the downloads section there seems to be 22, 24 and 44 pixels. |
Posted: Mon Apr 19, 2010 9:34 pm Post subject: |
Oh and can they be used with TomTom Speedcams? |
GerryC Pocket GPS Moderator
Posted: Tue Apr 20, 2010 9:35 am Post subject: |
The compatibility chart shows all are compatible so I would go for the 24 and 44 sets. The smaller one is used on the map and the bigger one for the alert in the top-left corner so you need both.
No, you cannot change the icons for the TT cameras. _________________ Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount |
FrequentFlyer Lifetime Member
Posted: Sat May 29, 2010 1:21 pm Post subject: |
Would you mind confirming for me too...I want the very largest available to show on both the route map and the top corner warning...(.the bigger, the better.I can barely see the camera on the map at present.) I'm running TT7 on a HTC Touch HD)Thanks. |
DennisN Tired Old Man
Posted: Sat May 29, 2010 5:02 pm Post subject: |
GerryC wrote: | I would go for the 24 and 44 sets. The smaller one is used on the map and the bigger one for the alert in the top-left corner so you need both. |
Gerry made them, so he's telling you the correct information. You can't use any larger. _________________ Dennis
Two of them are obesiting!! |
Posted: Sat May 29, 2010 5:16 pm Post subject: |
Be aware the OP is using TTN7 which is PDA based software, I am not too sure if the larger icons can be used with this software (never tried it myself) - Mike |
