Pocket GPS World :: View topic - Mount that stays on for a 520T?
PostPosted: Tue May 25, 2010 8:51 pm    Post subject: Reply with quote
There is also the accessory after market x20/ x30 mount called the "Easy Port" which can be modified in a similar way, to start you will need a Brodit Pro-Clip to suit your vehicle and the Brodit "Ball"
Have a close look at the top of the TomTom Easy Port x20/ x30 mount and you will see two rubber "plugs" these are simply levered out using your finger nails to reveal the two Phillips head screws:
Remove the two screws and the mount simply "falls appart"
Re-assemble the TomTom supplied parts to the Brodit "Ball" to end up with an assembly looking like this:
What does it look like in the car, well here is the mount in the Ovlov V70, power cable is routed through the air vent which avoids having wiring all over the cabin of the car:
With the device attached in the lower position:
The "Easy Port" x20/ x30 also offers the option to rotate the mount shoe through 180 degrees which offers a higher position for the PND:
22.051 (01 May 24)
