pete1336 Lifetime Member
Joined: Jul 22, 2006 Posts: 274 Location: North Wales
Posted: Sat Feb 13, 2010 8:25 am Post subject: Go 750 Brightness change-problem. |
Morning,
My go 750 has it's day brightness set to 95%and night level set to 10%. I don't use night colours. Can anyone tell me why when it's dark the brightness remains on the day setting?
I can't see anywhere the option which tells the unit to automatically switch from one level to the other. As it has a light level sensor (doesn't it?) I figured it should do it automatically.
All help gratefully received.
Pete. |
MrT Frequent Visitor
Posted: Sat Feb 13, 2010 9:08 am Post subject: |
Is the device on the mount? The sensor only seems to change brightness when it is on the supplied mount. _________________ Drivelux |
Oldboy Pocket GPS Moderator
Posted: Sat Feb 13, 2010 10:15 am Post subject: |
I don't have a 750 but do you have an option, in Brightness preferences, to Switch to night view when dark, and Turn brightness down when dark? _________________ Richard
Posted: Sat Feb 13, 2010 10:22 am Post subject: |
x40 and x50 units do need to be sat on/ connected to the car mount for the light sensor to work, the light sensor is really a waste of time in these models as its way too insensitive leading to the device switching between day/ night modes when driving under trees in daylight! - In the end I switched the auto stuff off - Mike |
falkirk81 Pocket GPS Verifier
Joined: Jul 07, 2006 Posts: 1649 Location: Newcastle, England, UK
Posted: Sat Feb 13, 2010 11:02 am Post subject: |
I thought the x50 series had its auto-light sensor disabled? And used the same method that the TT One uses whereby the unit knows what time darkness is where the unit is located?
Steven _________________ Tomtom GO 1005 LIVE
iPhone 12 |
Posted: Sat Feb 13, 2010 2:14 pm Post subject: |
It is on the mount supplied but this makes no difference. The light sensor seems not to work as it just does not dim at all when dark. There is the option to switch to night colours but frankly I think night view colours are pants. |
AndyVaughan Lifetime Member
Joined: Apr 13, 2006 Posts: 1500 Location: Rossendale
Posted: Sat Feb 13, 2010 2:31 pm Post subject: |
You canuse the same map colour scheme for the night settings as you do for the day settings, then at least you might get the auto dimming working.
The menus will still change colour though. |
Posted: Sat Feb 13, 2010 2:41 pm Post subject: |
How would one do that then Andy? |
Posted: Sat Feb 13, 2010 4:12 pm Post subject: |
pete1336 wrote: | How would one do that then Andy? | Use Change map colours menu options. _________________ Richard
Posted: Sat Feb 13, 2010 5:48 pm Post subject: |
Yep - exactly what I do on the XL LIVE
I use the same map colours for day and night but use the switch to night colours when dark option. The TT dims the brightness and switches the menus to the black background at night. |
IanS100 Frequent Visitor
Posted: Sat Feb 13, 2010 8:43 pm Post subject: |
I use the same map colours for day and night + the light sensor & it works fine on my 550 |
Andy_P Pocket GPS Moderator
Posted: Sun Feb 14, 2010 3:20 am Post subject: |
AndyVaughan wrote: | You canuse the same map colour scheme for the night settings as you do for the day settings, then at least you might get the auto dimming working.
Oldboy wrote: | pete1336 wrote: | How would one do that then Andy? | Use Change map colours menu options. |
That doesn't work on its own, as each colour scheme contains both the day AND night colour schemes. You only get the option to choose a complete set for day and night, you can't split the set up and ask it to use the "day" part of a certain scheme at night.
The only way to retain the day colour scheme is to tick the "reduce brightness when dark" box and un-tick the "switch to night colours when dark" box.
Then, if the light sensor is working and the device is on the dock, I think it should work.
Which unfortunately still doesn't explain why it isn't for Pete.
Have you tried a reset, or a return to factory settings, or a full software reinstall? (in that order of severity) |
Posted: Sun Feb 14, 2010 7:33 am Post subject: |
If you use the Advanced option in Change Map Colours you have a greater selection of Colour Schemes.
You can then choose the same scheme for both Day and Night. If you set them both to 100% then they look exactly the same in the Navigation Window.
Reducing the Brightness, for dark use, will still use the same colours but with less 'whiteness'.
You can even make it work the 'wrong way round'. _________________ Richard
Posted: Sun Feb 14, 2010 9:18 am Post subject: |
Is it different on the x50 to all previous TTs?
On my XL LIVE
Change Preferences
Change Map Colours
Advanced
Scroll through and select a day colour scheme
Scroll through and select the same colour scheme for night view
Now activate all of the switch to night view options and dim screen options. |
Posted: Sun Feb 14, 2010 7:36 pm Post subject: |
I think we are all talking about the same thing really, but might have slightly crossed wires.
What I was trying to say was that each colour scheme file contains the complete set of day colours and night colours.
Some of those colours you can change (using utilities like the Colour Scheme Editor) to be different for day and night, but some you can't - such as the white on black/black on white text colour.
But you can only (using the tick boxes I mentioned) opt to stay with the day part of the scheme for both day and night.
You cannot select the "night" part of the scheme for use in daytime for example. |
