Gee-Pee Lifetime Member
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Mon Jan 04, 2010 1:44 pm Post subject: |
rover220 wrote: | is there any known fix for this as yet? |
TT have today come up with a fix for me and it worked across two devices, each having, Kathy (UK Irish) voice installed. Basically it involves purging the voice from the device and then reinstalling it via HOME. This is the 'fix' that I was offered and it has worked OK.
Connect your device to your PC
Create a backup of your existing version of Kathy on your device –( located in the Voice folder)..
I think Kathy should be under the 2 files data162.chk and data162.vif.
( On mine Kathy was data119 and Kathy 1 was data 71 ), but you can check all the vif files to ascertain which one is the ‘Kathy’ file. (Or if you are having problems with another voice, then identify the two files .chk and .vif related to that voice)
When the files have been identified, then rename both of these files to data162.old1 and data162.old2
Open TomTom HOME, and go to Manage my Device, and remove Kathy( or other voice) from your device.
Do not choose to copy to your computer, when prompted
Check in C:\Documents and Settings\your user name\My Documents\TomTom\HOME\Download\complete\voice that there is no Kathy folder present
Go to Add traffic, Voices, Safety Cameras etc / Voices / Recorded Voices and search for Kathy
Select and add the voice to your device
This should be created as data119.chk and data119.vif in your ‘voices’ directory on your device.
check to see that the issue is resolved _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
Andy_P Pocket GPS Moderator
Posted: Tue Jan 05, 2010 12:43 pm Post subject: |
Gee-Pee wrote: |
When the files have been identified, then rename both of these files to data162.old1 and data162.old2 |
Assuming they meant you to rename the ones on the device rather than in the backup you just made, I wonder why? (as they tell you to delete them via Home in the next instruction) |
Posted: Tue Jan 05, 2010 1:04 pm Post subject: |
Andy_P wrote: | Gee-Pee wrote: |
Good point. I actually renamed them in the BackUp as I assumed they would remain on the computer and then having them deleted via Home in the next instruction, there would be no confusion with re-installing the same voice. I agree it was somewhat confusing. I have only copied and pasted the text of what TT told me.
Actually, I cannot see any point in backing up any voice.
Graham _________________ Gee-Pee
Posted: Tue Jan 05, 2010 1:07 pm Post subject: |
You might be right... I've noticed Home does have a habit of looking EVERYWHERE on your PC for files it might be interested in, rather then just in it's own download and backup folders.
So maybe they DID mean you to rename the ones you backed up! |
Posted: Tue Jan 05, 2010 1:23 pm Post subject: |
Anyway, my method worked, so I am satisfied and it seems that the problem was identified. Probably it got corrupted in the last software install. Who knows. There were some 'recovered' file fragments in the Voice folder.........
Did you get yours sorted, as I seem to remember you had a similar problem on one of your devices.
Posted: Tue Jan 05, 2010 2:57 pm Post subject: |
Gee-Pee wrote: | Probably it got corrupted in the last software install. Who knows. There were some 'recovered' file fragments in the Voice folder......... |
Be careful there.....
Windows itself uses the .chk file extension to refer to those fragments (often left over after a crash), but the TT doesn't know or care about Windows. To the TT the .chk extension is for an actual voice file!
Gee-Pee wrote: | Did you get yours sorted, as I seem to remember you had a similar problem on one of your devices.
Graham |
I had the v7 Kathy (with the fault), on my 940 but I still had the v1 Kathy on my 720, so I just copied that one over.
Maybe I'll get round to trying a new v7 download (following the method they suggested to you) later tonight. |
