mnealio Occasional Visitor
Posted: Fri Sep 18, 2009 10:39 pm Post subject: Tom Tom Error Messages |
please bare with me because i'm new to this, i've had my Tom Tom One since it first came out and hadno problems with it..............
Now since i have downloaded Tom Tom Home 2.6 when it loads up i get this error message
Component returned failure code: 0x80570015
and a lot of other codes but it will not let me copy and paste it on here for some reason............
hoping someone can help
now i havn't a clue what to do.......... can someone please help?
Posted: Sat Sep 19, 2009 12:47 am Post subject: |
Quote: | and a lot of other codes but it will not let me copy and paste it on here for some reason............ |
Remove all the "greater than" (or "less than") symbols. .i.e the straight line brackets. Then try reposting the error here. |
dhn Frequent Visitor
Posted: Sat Sep 19, 2009 3:30 am Post subject: |
Are you using Firefox as the browser? _________________ David |
Posted: Sat Sep 19, 2009 5:48 pm Post subject: |
You could try uninstalling 2.6 from the computer (using Add/Remove programs) and getting the latest application (2.7) from TT's site and try installing that.
Use this link _________________ David |
rjbsec Lifetime Member
Posted: Sat Sep 19, 2009 5:53 pm Post subject: |
Uninstall/reinstall will encounter problems unless the 'old' file is re-named e.g. Home_old. |
Posted: Sat Sep 19, 2009 11:00 pm Post subject: |
rjbsec wrote: | Uninstall/reinstall will encounter problems unless the 'old' file is re-named e.g. Home_old. |
hi, thanks for that info but how do i do that? i havn't uninstalled anything yet and will not do until i hear back
Thanks |
Posted: Sun Sep 20, 2009 7:44 am Post subject: |
mnealio wrote: |
Thanks |
When you uninstall Home it will still leave a file on your 'C' Drive "Tom Tom Home 2" or similar - if you leave it you will experence problems with the re-install.
So having uninstalled the old programme, go to Start / My Computer / C Drive / Program Files and search for the old Tom Tom file, e.g. 'Tom Tom Home 2' - right click on the file and select 'Rename' then change it to anything you want e.g. 'Home_old'.
Having done that, install the new Home programme.
After installation you can go back into Program Files and delete the file you renamed as 'Home-old'.
That is the response from Tom Tom Support that worked for me. |
Posted: Sun Sep 20, 2009 12:46 pm Post subject: |
Hi thanks,
I did that and when i installed 2.7 and it opened i just all a load of error messages again
at my wits end  |
Posted: Sun Sep 20, 2009 1:46 pm Post subject: |
mnealio wrote: | Hi thanks,
at my wits end  |
Oh dear - don't you just hate computers!
Can you take your PC back to the state it was in before you downloaded Home 2.6 on Friday?
Start / Help & Support / Tools / System Restore
Find the point where you downloaded Home (or as near as possible before) and select the option to restore you PC to then (it will return your settings etc to what they were before you downloaded - you won't lose any emails etc but it will affect any NEW programmes installed since that time).
Once it has completed the restore (it will need to restart you PC .. don't panic!) do what I outlined above AGAIN, i.e. uninstall the old Home (which should now be back to how it was before you updated) and then change the name of the file that is left over in Program Files after the uninstall.
So you should now have uninstalled Tom Tom Home and changed the name of the Tom Tom file in Program Files.
Now go to the Tom Tom website and download and install Home 2.7 - hopefully it will work successfully this time. |
Posted: Sun Sep 20, 2009 1:49 pm Post subject: |
That's another thought......
Have you rebooted the computer between the 2.6 uninstall and the 2.7 install? If not do a reboot now and try connecting the unit to Home again. _________________ David |
Posted: Sun Sep 20, 2009 3:18 pm Post subject: |
gonna do a system restore now will let you's know how i get on |
Posted: Mon Sep 21, 2009 3:27 pm Post subject: |
Long time, no hear - hope nothing worse happened  |
Posted: Mon Sep 21, 2009 11:03 pm Post subject: |
when i did the system restore i still had the version 2.6 and when i renamed it, and installed the 2.7 i still got all the error messages, so now i have removed all tom tom applications from my computer........ i know if i download it again the same thing will happen. |
Posted: Tue Sep 22, 2009 7:50 am Post subject: |
That is weird, I had issues but as soon as I did the uninstall, re-name and re-install my problems went away. Obviously something is causing a conflict on your PC, sometimes anti-virus programmes can do this; on one of my laptops I had Avast A/V installed and it would regularly cause the laptop to crash - had to remove it and now all is well.
There is a piece of free software that I use regularly called CCCleaner that removes all 'rubbish' left on a PC, including in the registry - you could do the restore again, then run CCCleaner and try again but beyond that I'm afraid that I don't have any further suggestions.
Edit
You didn't say you uninstalled 2.6 after the restore - did you miss that step |
