bkilham Lifetime Member
Posted: Sat Oct 03, 2009 5:25 pm Post subject: A3 to Wisley Gardens |
Can anyone tell me why the route from the A3 turn off to Wisley Gardens is over 8 miles out of the way instead of a few hundred yards? I have looked at restricted turns and one way options but can't find the answer. _________________ Brian
2 x GO550's
Sygic app for Android (rubbish voice guidance) |
Oldboy Pocket GPS Moderator
Posted: Sat Oct 03, 2009 7:23 pm Post subject: |
My guess is that there is a Turn restriction in place where the Wisley Lane filter is.
If you plan a route from the Filter Lane it works OK. If you move back, by 10m, onto the A3 the routing is as you say.
Unfortunately I don't think there is anything you can change on the Map itself to correct this. TT Map corrections allow for a turn restriction to be put in place, but hasn't the menu options to remove one.
All you can do is report it to TT as Other Error, and hope it is corrected in the future. _________________ Richard
Posted: Sat Oct 03, 2009 8:56 pm Post subject: |
It's possible to plan a route from the A3 via the exit lane onto the very start of Wisley Lane, near the triangle, but a few yards further and it goes off on a detour. It's also possible to start at the exit lane to Wisley Gardens.
I have just tried a "work around" by using the itinerary planner and adding the A3, the exit road and then Wisley Gardens and it takes you the correct route. _________________ Brian
2 x GO550's
Posted: Sat Oct 03, 2009 9:19 pm Post subject: |
Guess what?
I found the very simple solution of selecting to "travel via" the A3 exit road onto Wisley Lane.
Regarding the turn restrictions, I found a while ago that it can be changed, as coming out of Blenheim Palace there was a "no right turn" restriction on the Tom Tom map which could be changed under the "Correct Location" menu. _________________ Brian
2 x GO550's
