Pocket GPS World :: View topic - Mapshare Gremlin's at work ?
Goto page Previous  1, 2
maca2
PostPosted: Sat Aug 15, 2009 12:55 pm    Post subject: Reply with quote
mikealder wrote:
To make sure this isn't due to IQ Routes data you should also specify date and time of travel and the rough start/ finish locations as these will all have a bearing on the route the device decides to use. In addition what Navcoe version and map release have you got installed? - Mike
My maps version is 8.351 & since removing all mapshare updates & not running any new update it is back to normal so this problem is with mapshare.
PostPosted: Sat Aug 15, 2009 2:13 pm    Post subject: Reply with quote
That is the Navcore software version number not the map version which will be something like v830 if its current, still it sounds like you have found the answer to the problem which is stop degrading your map by turning MapShare OFF - Mike
maca2
PostPosted: Sat Aug 15, 2009 4:11 pm    Post subject: Reply with quote
Yes it's now turned off.
Thanks for your help
Page 2 of 2
22.052 (08 May 24)
