Pocket GPS World :: View topic - WINXP Back up of my TT720 won't work today
peasemore
PostPosted: Thu Aug 06, 2009 3:28 pm    Post subject: WINXP Back up of my TT720 won't work today Reply with quote
Though I've done successfully before I find today that XP won't allow me to paste my TT hard drive into a new PC folder; says it can't copy from Kate file.
Any advice valued.
http://www.peasemore.plus.com/TT%20CopyGrief.GIF
Gel
Lifetime Member Thames Valley, Berkshire, UK
Mazda CX-5 built in SatNav- not sure if TT or not. Garmin NUVI in reserve.
PostPosted: Thu Aug 06, 2009 3:41 pm    Post subject: Reply with quote
I wouldn't worry about that too much as the kate voice can be downloaded using Home with the device connected or you can grab it yourself using this link British Kate Voice - Mike
peasemore
PostPosted: Thu Aug 06, 2009 3:45 pm    Post subject: Thanks Reply with quote
Thanks, but clicking OK at this point stops the copying at 30%.
Just tried again, and seems to be going OK this time. Wink
Gel
PostPosted: Thu Aug 06, 2009 3:54 pm    Post subject: Reply with quote
You only really need the map folders backed up as eveything else can be added from downloads, it just takes a while providing all the links! - Mike
PostPosted: Fri Aug 07, 2009 3:40 am    Post subject: Reply with quote
In this sort of situation, you can always try copying "around it".
In other words copy everything EXCEPT the folder that the rogue file is in (in this case it's probably \LoquendoTTS\data\voices\Kate).
Then you can try copying all the files inside that folder apart from the one duff file and put them in a new folder you make yourself with the same name as the original folder.
That way you get a backup of everything you can.
