Pocket GPS World :: View topic - TT3 upgrade probs
TT3 upgrade probs
dmac
PostPosted: Sun May 09, 2004 10:42 am    Post subject: TT3 upgrade probs Reply with quote
Upgraded to TT3 after performing hard reset on IPAQ 2210 and all
seemed to work well, able to check routes etc with BTGPS connection.
Decided then to dwwnload checkpoint and speed camera database.
Restarting TT met with out of memory error message.
Another hard reset on machine and even upgraded to TT3 3.02 which
is meant to cure BT connection probs.
Nothing else loaded apart from TT but get "sorry not enough programme memory"..................... "out of memory [1035]"
Any advice most welcome as I thought hard reset should have cured all
ills.........
DavidW
PostPosted: Sun May 09, 2004 2:15 pm    Post subject: Reply with quote
If you've put the postcode database file in main memory, you're probably rather short of memory. I believe there's something like 56MB usable on a 2210, and taking 19MB for a data file is going to leave you stretched.
Remove UK Postcode. If the problem goes away, put the UK Postcode data file and program on your memory card, and just the shortcut in main memory.
I presume you mean GPS 3.02 - at this time, the latest versions are Navigator 3 3.01 and GPS 3.02. There is not (yet) any Navigator 3 3.02.
22.054 (22 May 24)
