Pocket GPS World :: View topic - Saving routes to internal memory rather than SD card
Mike777
PostPosted: Tue Jun 02, 2009 7:05 pm    Post subject: Saving routes to internal memory rather than SD card Reply with quote
Hi all
I am sure this can be done but I am unsure how
Can anyone please help.
Many thanks
Mike
LostMike
PostPosted: Tue Jun 02, 2009 8:35 pm    Post subject: Reply with quote
Have you tried moving the protection slider on the SD card so it is write protected?
I think everything should then be saved to internal memory. Though I have not tired this as I have no need to do so.
LostMike
Satmap A10. Platform 21
Software version 1.5.9193
Satsync 1.525
PostPosted: Tue Jun 02, 2009 10:13 pm    Post subject: Reply with quote
Select the Route you want to move/ copy to the SD card then select "Edit you will find the following options:
Move Route to SD card
Copy Route to SD card
I used this technique earlier this evening to copy a route I had created on my device on to another forum members SD card so we both had the same data sets to follow - Mike
jonesbach
PostPosted: Tue Jun 02, 2009 10:25 pm    Post subject: Reply with quote
LostMike's suggestion worked in Version 1.3. The only issue at that time was that a phantom file was shown as being on the SD card. This phantom file disappeared on powering down.
Mikealder is also correct but I believe you want to go the other way, follow his directions but select the file on the SD card and you'll get the prompt to move to memory.
Mike777
PostPosted: Wed Jun 03, 2009 12:32 pm    Post subject: Reply with quote
This work fine so thanks............
My problem was when it saved to my SD card I could not export the route. I could copy it but it copied as a file rather than a .gpx file so would I could not import into the map based software I used.
I am using the lastest software and platfrom so I wondered if this is normal.
Another question was when I converted a track to route even thought I had no route active on my active 10 the route was still being shown in grey on the active 10 map. Any ideas
Many thanks
Mike
philpugh
PostPosted: Wed Jun 03, 2009 1:43 pm    Post subject: Reply with quote
This is normal for the Active10. It will display any inactive routes in grey - quite a nice feature if, like me, you plan a set of routes to cover different eventualities - you see an active route in Yellow/Orange and the alternatives in Grey. You can turn this option off in the device settings I believe.
Phil
22.052 (08 May 24)
