Pocket GPS World :: View topic - Data transfer speed
Data transfer speed
eddie986
PostPosted: Sat May 16, 2009 8:19 pm    Post subject: Data transfer speed Reply with quote
A quickie question. What is the max data transfer speed on the TTgo 530t. Can't find the info anywhere. I want to use an sd card for music and use the fm transmitter to radio facility. Thanks
Cheers Edd
TomTom Go 530t
App 8.350 (9980/090427) OS:310360
GPS v1.20, Boot 5.5120
Map: 'UK and Rep of Ireland' v810.1870
PostPosted: Sat May 16, 2009 9:27 pm    Post subject: Reply with quote
The 530T supports USB-2 so connection to the PC is very quick for data transfer, even if you put a large capacity SDHC card in the device it will still get the mp3 files on to the device quite quickly.
The device will support cards up to 32GB capacity, which is a heck of a lot of music, you will need to put a folder on the card named "mp3" (without the "" and it must be all lower case), the music folders and files go in the mp3 card otherwise the device won't find them.
If you already have a large collection of music its a simple file copy job, if not you will have to rip the music to mp3 format, the TomTom will not support anything other mp3 and try to avoid sampling rates at 320KBPS as it struggles with these, 192KBPS gives a better compromise - Mike
eddie986
PostPosted: Sun May 17, 2009 10:11 pm    Post subject: Reply with quote
Thank you for reply
Just the job
Cheers Edd
TomTom Go 530t
22.052 (08 May 24)
