cuk0724 Occasional Visitor
Joined: 04/08/2003 20:00:20 Posts: 44 Location: Essex
Posted: Mon May 17, 2004 2:23 pm Post subject: |
Lets hope that it works.
I have not had any further reply form TomTom as yet. |
Posted: Mon May 17, 2004 4:16 pm Post subject: |
Just changed the reg setting, made no difference. Run for about 2 mins then started to lose GPS data and then get it back again after about 1 sec. It run for 5 mins and then did not get data back. One thing I did notice was that when it locked up the blue light on the receiver was still on full even when I shut down TomTom. |
RBloxam Occasional Visitor
Posted: Mon May 17, 2004 6:24 pm Post subject: Bluetooth dropouts on h2210 |
I have similar bluetooth drop outs with h2210 and Holux GR-230 receiver since November 2003. Originally I used TTN2 and tracked the problem down to use of the SD card. When I switched the maps to Compact Flash I had hardly any lockups at all (very rare). Some SD cards seems to be worse than others, this may be why not everyone is exeriencing the problem. I have had more sucess with the viking 256MB CF (Toshiba) card.
I now have TTN3 upgrade and find the same problem. Have tried switching between the CF and SD today and the problem only happens when using the SD The lockup is worse using TTN3, often it needs a reset to sort it out. I use:
Integral 128MB CF
Unbranded SD (supplied by Holux with Package)
Viking 256MB SD (Toshiba)
h2210 ROM 1.00.10 ENG 05/22/03
BtReg Tweak
Checkpoint
Hope this helps some other long suffering h2210 user.
Richard |
iancjc Frequent Visitor
Joined: 10/02/2003 14:19:44 Posts: 749 Location: United Kingdom
Posted: Mon May 17, 2004 7:47 pm Post subject: |
re the sd card this was my experience as well.
There is a sdio update for the 2210 on the hp site - maybe worth a try - but ultimately it looks like ttn3 works the flash cards even harder than ttn2, strange that the obvious symtom is the bt connection - perhaps because it is obvious when it stop working where other processes are less visible?
I for one am thinking of ditching tomtom but have no idea what else to try - I want the camera database warner plus decent maps and addresses - any suggestions.
Ian _________________ -----------------------------------------------------------
TTN6.03 tomtom 7.xx (one) |
Posted: Mon May 17, 2004 8:14 pm Post subject: |
As far as it goes with SD cards, I have tried 2 different SD card and 2 different CF cards. It does not any difference |
Posted: Mon May 17, 2004 8:16 pm Post subject: |
One day I will learn how to type. It should have said it does not make any difference!!! |
ianbagley Occasional Visitor
Posted: Mon May 17, 2004 9:36 pm Post subject: Another solution for some? |
I've found that disabling the sound within TT fixes my dropout problem.
I noticed that i always seemed to get the dropputs at junctions and roundabouts.... i.e. where the voice tells me where to go... I'm not bothered about missing the voice so this 'fix' works for me.... and i'd tried just about everything else and was getting sick of TT packing up on me! |
gregh Regular Visitor
Joined: 27/04/2003 17:15:12 Posts: 129 Location: United Kingdom
Posted: Tue May 18, 2004 2:04 pm Post subject: |
I have a 2210, Fortuna clip-on, with maps and TomTom on CF and don't see any dropouts.
Greg |
SPY Occasional Visitor
Joined: May 15, 2004 Posts: 30 Location: Hertfordshire
Posted: Tue May 18, 2004 8:37 pm Post subject: |
TomTom asked me to re-install 3.02 GPS driver then delete BT shortcut & rebond. This as expected had no effect.
They have now suggested I uncheck the Show POI option in Navigator as a possible temporary fix.
I'm not expecting success but thought I'd share the info with other sufferer's!
Ipaq 2210 - Holux GR-230 BT - TTN3
Rom 1.10 GPS 3.02 |
jasper Occasional Visitor
Posted: Tue May 18, 2004 11:37 pm Post subject: |
Hello 2 all
I've had Tom Tom 3 ver 3.01 for about 6 days and have a ipaq 2210,gps clipon
I installed it ! and as u all know i'm now having bluetooth dropouts ,so i had a look here and i've tried everythink but still no good.
But then i tried moving the map file from my SD card to my CF card (Tom Tom 3 is installed on the ipaqs main memory) and bingo !!! it has started to work so far.
Before i've only been able to get about 2 mins connection but i've just been out on a 15 min drive and it has stayed connected.
Hope this helps some of u its not a fix but it works !
Thanks for all u for the help on this site :D
ps using ver 3.01 and gps driver 3.02 |
Big_E Occasional Visitor
Posted: Wed May 19, 2004 12:16 am Post subject: |
TURBO - see my ealier post with regards to POI, your experience sounds exactly the same as mine, I could sit here in the house with the GPS in the garden and get 6 hours of uninterrupted sat updates, the moment you go on the road, it goes t*ts up.... Please try it, let me know in my thread what you find!
Ian. |
Posted: Wed May 19, 2004 12:48 am Post subject: |
I have been using GPS driver ver 2.07, because I know that worked with TomTom ver 2. I still get the lock up, but after I un-checked the POI's it has worked fine on a 2 hour drive home. I will try it with GPS ver 3.02 later. |
Posted: Wed May 19, 2004 5:16 pm Post subject: |
Well I put driver version 3.02 back on, and with the Show POI's un checked, have had no drop outs all day. I then checked the show POI's box, and within 2 mins got drop outs.
It would seem that this may have fixed the problem!!
Only time will tell
Still no contact from TomTom support now for 6 days, despite updating them each day!!! |
Posted: Wed May 19, 2004 6:00 pm Post subject: Bluetooth drops |
The underlying issue / problem here is that the bluetooth stack is dropped when the pda processsor is working too hard. Disabling POIs will help as does the use of Compact Flash cards, they work the pda processor less due to the fact that CF cards have their own disk controller buit in, the SD cards do not. This is why you only get the drop outs when the maps are moving and the processor is stretched. The bluetooth connection will keep connected for as long as you wish when stationary.
h2210
TTN3 3.01 (409/2)
GPS V3.02
128MB CF with complete GB Map (101MB)
NMEA 0183v2 9600
Bluetooth Serial Port COM8:
Holux GR-230 |
Posted: Wed May 19, 2004 6:58 pm Post subject: |
I too can report no dropouts on several short (5-10 min) journeys since removing POI. The problem is that POI was the reason for choosing TTN3!
Ipaq 2210 - Holux GR-230 BT - TTN3 (409/2)
Rom 1.10 GPS 3.02 Unbranded Holux Supplied 256Mb SD. |
