Pocket GPS World :: View topic - 720t Problems again
720t Problems again
Goto page Previous  1, 2
volkswarren
PostPosted: Mon Apr 06, 2009 9:23 pm    Post subject: Reply with quote
Mike that sounds great, sounds like the audi amplified aerial uses a seperate live feed so there should be no power down the coax, I will check that 1st though Smile
AndyVaughan
PostPosted: Mon Apr 06, 2009 9:36 pm    Post subject: Reply with quote
Same as a vauxhall then by the sounds of it.
I didn't splice in to the wiring - I took the aerial base off and soldered a seperate coax to the amp output and ran this under the headlining, down the a pillar behind the trim and terminated it in a standard car coax socket. I then replaced the standard TT 'aerial' wire with a short length of coax terminated in a standard car coax plug. No visible wiring when the TMC is removed from the car.
Good luck, it makes a huge difference in weak signal areas.
Andy
PostPosted: Mon Apr 06, 2009 9:42 pm    Post subject: Reply with quote
mikealder wrote:
I should have a guide complete with pictures available by Saturday night if thats any help.
Will it be OK if some of us don't feel tempted by this? I Did some IT Myself this last weekend, assembling a flatpack two pedestal desk and had to un-assemble it in the end - three funny screws wrong and I'd got a shelf on back to front. Bit of a record actually - got it finished in less than two days! The door opens and all the drawers slide out and back in (although I'll not be doing a lot of opening and sliding, tempting fate).
Page 2 of 2
