DennisN Tired Old Man
Posted: Sat Mar 14, 2009 3:53 pm Post subject: Outlook Express |
Windows XP Pro 64bit edition. Outlook Express 64bit.
I am about to get a new PC and want to transfer my existing Outlook Express folders to it. I see an option in File.. Export.. Folders. But when I go for it I end up with it saying the export doesn't work, error initialising MAPI.
Means absolutely nothing to me (except that it won't export the rotten folders!).
I have found the folders (.dbx) buried about 15 levels down in Documents and Settings. Do you reckon simply copying these to my external USB drive for copying back to the new machine will work - new machine will be Vista 64bit and presumably using Windows Mail (or somesuch) under Vista. _________________ Dennis
Two of them are obesiting!! |
Darren Frequent Visitor
Posted: Sat Mar 14, 2009 4:07 pm Post subject: |
Why are you still using Windows when you have a MacBook? For transfer of OE follow this guide. _________________ Darren Griffin |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Sat Mar 14, 2009 6:23 pm Post subject: |
You can use the:
Windows Easy Transfer
to copy your mail etc to the new machine. |
Mullet Frequent Visitor
Posted: Sat Mar 14, 2009 7:32 pm Post subject: |
Been a while since I used Express but IIRC, you can select all mail within the inbox for example and simply drag and drop to a new folder on a pen drive or wherever (the copy option does not appear in the context menu or menu bar). Then open the inbox on your new mail application then drag and drop the emails in to the message pane. Repeat for other folders.
Doubles as an effective method to backup email. |
Posted: Sun Mar 15, 2009 1:34 am Post subject: |
Pocketgps wrote: | You can use the:
to copy your mail etc to the new machine. | This sounds like just the thing for me - the description indicates you can use it to transfer files and settings, including email settings, via external drive which I have. Only thing is, I did the download, then clicked on the install, it said it had installed, but there's no sign of the program anywhere!! _________________ Dennis
Posted: Sun Mar 15, 2009 1:41 am Post subject: |
Darren wrote: | Why are you still using Windows when you have a MacBook? For transfer of OE follow this guide. | I have ten years' business records on Lotus 123 which isn't available for Mac. And that man's methods don't work for me (doesn't produce a WAB file for the address book, although that's not a problem as I have that on my webmail and presumably can export it from there).
Maybe my next desktop will be a full blown Mac as I really like them. _________________ Dennis
Posted: Sun Mar 15, 2009 3:18 am Post subject: |
DennisN wrote: | Pocketgps wrote: | You can use the:
to copy your mail etc to the new machine. | This sounds like just the thing for me - the description indicates you can use it to transfer files and settings, including email settings, via external drive which I have. Only thing is, I did the download, then clicked on the install, it said it had installed, but there's no sign of the program anywhere!! |
Have a look for a file called:
migwiz.exe
Windows / System32 / migwiz / migwiz.exe |
Posted: Sun Mar 15, 2009 9:00 am Post subject: |
OK, at least we're in the trees, now for the wood...
I have four copies of migwiz.exe in ...
Windows\ServicePackFiles\i386\migwiz.exe - 241KB 18/02/2007
Windows\ServicePackFiles\amd64\migwiz.exe - 293KB 16/02/2007
Windows\system32\usmt\migwiz.exe - 293KB 16/02/2007
Windows\SysWOW64\usmt\migwiz.exe - 241KB 18/02/2007
These last two directories also have migwiz.exe.manifest - 2KB 25/03/2005 _________________ Dennis
Posted: Sun Mar 15, 2009 12:51 pm Post subject: |
Personally, when backing up my own data or safe guarding others data, i just copy the DBX files to a DVD and copy the WAB file from
c:\documents and settings\user name\application data\microsoft\address book
The "wizards" etc never fail to disappoint me...
You can Export the account setting from within OE by opening the Tools Menu, selecting Accounts, highlighting the Account and clicking Export...
Do the same on the new PC but use Import to import the accounts.
Use File, Import, Messages, Outlook Express 6, Import from OE6 store directory to import the emails
Use File, Import, Address Book to import the address book... |
Posted: Sun Mar 15, 2009 10:27 pm Post subject: |
DennisN wrote: | OK, at least we're in the trees, now for the wood...
These last two directories also have migwiz.exe.manifest - 2KB 25/03/2005 |
I have not searched my pc. The directory I showed above is from the start menu on my Vista 32 system.
Start - Programs - Accessories - System Tools - Windows Easy Transfer
And that shortcut points to it. |
