Pocket GPS World :: View topic - Camera Files in a folder
Burn180
PostPosted: Mon Feb 23, 2009 7:28 pm    Post subject: Camera Files in a folder Reply with quote
When I put my POI in my Garmin SD card using POI_Loader I have to have it like this
If I put the Camera files in it's own folder like the other POI's they wont show on the carmin Nuvi 760 they just show as grey dots
PostPosted: Mon Feb 23, 2009 7:41 pm    Post subject: Reply with quote
None of the POIs should be in folders of their own. They should all be bundled into one folder and POILoader will then read that folder and upload its contents.
As you have it currently in your image, ONLY the camera POIs will install.
Pocketgps
I’ve had all of my Garmin's for several years. At no time could I use multiple folders to load poi’s to them.
As far as I know ALL the files have to be in one folder only, which you then browse too in PoiLoader.
It then loads them all at that time, and complies them in to one file.
Burn180
PostPosted: Mon Feb 23, 2009 8:01 pm    Post subject: Reply with quote
I have 1 folder in that folder is what you see above POI_Loader reads this and input it to the SD card fine.
If you look in the picture there are camera files all over the place if I put this in a folder like the rest the Nuvi wil thenl only see it as grey dots.
so the Folder structure I have is
PostPosted: Mon Feb 23, 2009 8:05 pm    Post subject: Reply with quote
You misunderstand. When you run POILoader, you tell it which folder contains your POI files.
POILoader expects ALL the POIs to be 'loose' in the folder you tell it to look in. You cannot have sub-folders within the folder containing all your POIs neatly organised as you have above, this will not work.
As you have them organised now, assuming the parent folder is called POIs and inside this is all those folders and files, then POILoader will only install the loose camera POIs. It will completely ignore all the others.
Burn180
PostPosted: Mon Feb 23, 2009 8:10 pm    Post subject: Reply with quote
but it hasn't it has uploaded the lot. It's uploaded the POI folder plus all the camera files & folders. I have always done it this way.
PostPosted: Mon Feb 23, 2009 8:19 pm    Post subject: Reply with quote
In your example you have individual folders within the POI folder. You cannot do this. It should look like this:
Burn180
PostPosted: Mon Feb 23, 2009 8:21 pm    Post subject: Reply with quote
you can do it the way I have done it, because I have. It has uploaded fine
Garmin Nuvi 3790T Firmware 4.30
Also Owned
Garmin Nuvi 200W, 760, 770, 765T
PostPosted: Mon Feb 23, 2009 8:25 pm    Post subject: Reply with quote
So what do you have under Proximity Points on your device?
Burn180
PostPosted: Mon Feb 23, 2009 8:33 pm    Post subject: Reply with quote
If I go to (Tools-Settings-Proximity points-Change) I see (Garmin Saftey Cameras) this does not have a tick in the box. I also see (Custom POIs) this does have a tick in the box
Now if I go to (Where to-Extras) I see (Custom POIs) I click it and I see
If I click any of the categories I get a list of that category
Also Owned
Pocketgps
PostPosted: Mon Feb 23, 2009 9:23 pm    Post subject: Reply with quote
Well I must admit that I have just tried your way of loading the poi's within different folders, and it works. Perhaps this is a feature that has been added to PoiLoader over the last year or so. But I am sure that you could not do this in the earlier versions.
Forgot to try the safety camers in a separate folder. But all other poi's I left in their folders and placed those folders within the safety camera folder and it loaded them all okay. I know this because I loaded some test poi's just to see. And they are all there in their different categories.
PostPosted: Mon Feb 23, 2009 9:45 pm    Post subject: Reply with quote
Well <expletive> me! When did that creep in? [rushes off to test]!
Burn180
PostPosted: Mon Feb 23, 2009 9:48 pm    Post subject: Reply with quote
I've been doing this way for 2 years, since I got my Nuvi 200W my first satnav. The strange thing I found is if you put the camera files in there own folder like the rest of the POIs the Nuvi will only show them as grey dots not camera symbols
My structure, to me makes a lot more sense especially when it comes to updating your POIs.
Edit
You can put the camera files in a folder Very Happy they seem to have fix the bug I was having.
Also Owned
PaulB2005
PostPosted: Mon Feb 23, 2009 10:43 pm    Post subject: Reply with quote
The grey dots bug in normally caused by having more than 255 categories in one folder.
Burn180
PostPosted: Mon Feb 23, 2009 10:46 pm    Post subject: Reply with quote
yep that's it. If I add the MP3 speed camera files as well they go grey
Also Owned
