linknet Frequent Visitor
Posted: Tue Jun 02, 2009 7:19 pm Post subject: |
webpatrick wrote: | I modified the 6.0.21 version a bit:
- nicer background for speed indication (including dropshadow)
- some enhanced speed and camara backgrounds
- colored battery indicator (green=full, red=empty and some colors in between) |
Well thanks a lot, that's made a mess of all my carefully created speed indication bitmaps, never mind the fact that the drop shadows don't work properly in landscape mode and there isn't any VGA support.
If you must modify the skin at least do it properly and then give it a different name so at least everyone will know that it has been modified and then post it in a different thread..
linknet |
DefenderBLACK Lifetime Member
Joined: 23/06/2003 17:45:35 Posts: 103 Location: United Kingdom
Posted: Tue Jun 02, 2009 7:32 pm Post subject: |
when running simulate / fly over it plays for so long then comes up with out of memory? |
Posted: Tue Jun 02, 2009 10:18 pm Post subject: |
DefenderBLACK wrote: | when running simulate / fly over it plays for so long then comes up with out of memory? |
How much free memory have you before running iGO8 ?
linknet |
Posted: Tue Jun 02, 2009 11:10 pm Post subject: |
storage:-
allocated36.03mb in use 18.02mb free 18.01mb
PROGRAM:-
allocated 27.06mb in use 7.96mb Free 18.09mb
total main mem 63.09mb
installed TomTo7 on storage card and igo8 too.
other than standard programs that came with windows only added nydiot v4 screen rotation prog for use with TT7 |
Posted: Wed Jun 03, 2009 8:00 am Post subject: |
DefenderBLACK wrote: | storage:-
PROGRAM:-
allocated 27.06mb in use 7.96mb Free 18.09mb |
So there's only 18.01 + 18.09 = 36.1 MB free.
I think there are some settings for sys.txt which will restrict the amount of memory used but you'd need to do a search for them.
By the way, did you manage get the Ultra Skin to work ?
linknet |
Posted: Wed Jun 03, 2009 7:31 pm Post subject: |
where do i look for sys.txt and what do i do with it when i find it?
Couldnt get ultra to work kept getting the error messages as mentioned in one of my posts :-((
Can get some others to work ie gurjon skin 6.6p but can crash with mem probs sometimes! |
Posted: Wed Jun 03, 2009 10:24 pm Post subject: |
sorry missed off :-
have put your zip file in (unzipped) in to folder :-
storage card/igo8/content/skins
but crashes on startup
found sys.txt on storage card and reads :-
[folders]
app="%SDCARD%/iGO8"
[interface]
maxzoom2d=6000000
show_exit=1
[map]
2dheadup=1
[interface]
skin="ui_igo8"
note running the gujon skin as mentioned. |
Posted: Wed Jun 03, 2009 11:26 pm Post subject: |
This thread is only to provide support for the Ultra Skin. I've provided details for updating your version of iGO to support it but for some reason you've decided not to take it. So that's as far as I go with this.
linknet |
Posted: Thu Jun 04, 2009 7:13 am Post subject: |
Thats why i have posted saying i couldnt get it to work. But i thought i should see if i could get another earlier version of yours working (v5 etc) and COULDNT ???????????
I then tried another skin as I mentioned and found that worked, that way you know that the fault lies with the skin software you are trying to use rather than the device etc, comon sense. Im not struck on the other skin - HENCE THATS WHY IM TRYING TO GET YOURS TO WORK!!! None of your skin will work for some reason, hence trying to sort it here and even get an older version working!
Also have reformatted the card each time (lost count)between installing yours and trying other versions so as to mske sure of NO conflicts. How many do that i wonder!!
My point as to your short sharp reply is I would still like to use your skin version - I havent asked in this thread for help on any other skin thank you very much!! |
Posted: Thu Jun 04, 2009 9:10 am Post subject: |
DefenderBLACK wrote: | ... and even get an older version working! |
Version 5.0 of the Ultra Skin is not designed to work with the 8.3.2.64029 version of iGO8 so there's no point in trying that.
DefenderBLACK wrote: | None of your skin will work for some reason... |
I've given the reason for the errors you are getting with iGO 8.3.2.64029 and the Ultra Skin 6.0.21:
Quote: | If that's the case then the FFUI errors you are getting with the Ultra Skin 6.021 are the result of a data.zip file which doesn't match the version of iGO8 that you are using.
You need the correct data.zip file for the 8.3.2.64029 version of iGO8. |
I've given the method to use to correct this problem:
Quote: | The data.zip file for iGO 8.3.2.64029 is dated 7 November 2008 14:41:46
You need to visit https://www.naviextras.com/shop/portal and update your version. This is the only legal way to do this. |
I'm beginning to suspect that the version of iGO you have is not legal which would explain the presence of the wrong data.zip file and also explain why you are unable to update the software.
So first visit here and update your version:
... and then if the skin doesn't work let me know.
linknet |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Thu Jun 04, 2009 3:18 pm Post subject: |
Quote: | Also have reformatted the card each time (lost count)between installing yours and trying other versions so as to mske sure of NO conflicts. How many do that i wonder!!
My point as to your short sharp reply is I would still like to use your skin version |
As an iGO user I assume you backed up the original SD Card. The software is locked to the card so you should be able copy the backup to the original card and do a fresh install.
Add Linknet's Skin to the Skin folder in iGO8/Contents.
I can't remember mine having a skin folder and if I remember rightly, I had to add it.
Now go to Settings and change the Skin to Linknet's, you then need to re-start iGO and it should work. _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
pt_riga Occasional Visitor
Posted: Fri Jun 12, 2009 10:48 pm Post subject: |
Hello Linknet.
I'm a big fan of your skin and i've been using it for many years now.
Congratulations for your fine work!
I have a question for you.
In the last dimkaspecter skin there is a very useful option (for me, anyway...) that allows us to change the maps used in navigation from teleatlas to navteq and vice-versa.
Are you familiar with that and do you think that is possible to include it in your skin in one of the next revisions? |
Posted: Sat Jun 13, 2009 8:02 am Post subject: |
pt_riga wrote: | In the last dimkaspecter skin there is a very useful option (for me, anyway...) that allows us to change the maps used in navigation from teleatlas to navteq and vice-versa.
I'm not that familiar with it but presumably it changes between the map folders on the SD card. Do you know if it requires a restart ?
Having had the loan of an iGO Amigo device for a few weeks I'm hoping that Nav'N'Go will bring out a new version of iGO 8 with a similar interface but including more of the advanced features of iGO 8. So at the moment any further development of the Ultra Skin is on hold unless any more bugs are found.
Regards
linknet |
Posted: Sat Jun 13, 2009 10:45 am Post subject: |
linknet wrote: | pt_riga wrote: | In the last dimkaspecter skin there is a very useful option (for me, anyway...) that allows us to change the maps used in navigation from teleatlas to navteq and vice-versa.
Regards
linknet |
Yes, it does change the folders used (renaming them) and yes, it requires a restart to change the maps, but that is done automatically.
I looked into the .ui files and I understand the "mechanics" of it, but putting it to work, well, that's a bit more dificult for me
About the Amigo interface, I've only seen the screenshots from some of the skins made for it and I really don't like it.
I don't know why, but it reminds me a kids game, perhaps because of the colors or the icons.
For now I will just stick with my good "old" iGO8 (and your skin, of course! ) |
TheGrumbler Occasional Visitor
Posted: Sun Jun 14, 2009 1:29 pm Post subject: |
linknet,
why do you still refer to version 8.3.2.64029? Even though the latest official update release is:
8.3.2.87762 from Date: Apr 27 2009 - Official Retail R3 PDA Update
As far as I can judge your Ultra Skin 6.0.21 is working fine on this newest version also.
Or do you mean at least version 8.3.2.64029 is needed?
TheGrumbler |
