Pocket GPS World :: View topic - Tom Tom ONE version numbers help....
PostPosted: Sun Feb 08, 2009 3:17 pm    Post subject: Reply with quote
Please note "One (Vx)" where x is a number is the version number that TomTom Home software will identify the device as, this is not necessarily the version numbers used by TomTom or their retailers.
One (V1) HERE
Original One
Front
Back
Top
Base
One (V2)
Never existed
One (V3) HERE
Credit and thanks to to "ben_e71" for the information and pictures.
SD card only no internal flash memory and has Bluetooth for connection to a mobile phone for data via GPRS only.
Box
Front
Top
One (V4) Credit and thanks to to "Kar98" for the information and pictures.
SD card slot and 1GB of internal memory
Front
Back
Top
Base
One (V5) HERE
Original One XL
Four different versions of this device were introduced:
European with 1GB of flash memory, an SD card slot and RDS-TMC connection point. Bluetooth for connection to a mobile phone for data via GPRS only.
Regional with 512MB of flash memory, an SD card slot and RDS-TMC connection point. Bluetooth for connection to a mobile phone for data via GPRS only.
Regional with no internal flash memory fitted with an SD card and RDS-TMC connection point. Bluetooth for connection to a mobile phone for data via GPRS only.
An American market version was also produced which used the excellent Text To Speech system only seen on the higher end Go x10, x20, x30 and x40 devices, this was known as the One XLS
Front
Back
Top
Base
One (V6) HERE and HERE
One Third Edition Europe model
1GB of flash memory, no SD card slot, no Bluetooth, RDS-TMC connection point. Reduced functionality of menu system, no Itinerary planning mode.
Front
Back
Top
Base
[b]=============================================================
One (V7) HERE and HERE
One Third Edition Regional Model
512MB of flash memory, no SD card slot, no Bluetooth, RDS-TMC connection point. Reduced functionality of menu system, no Itinerary planning mode.
Front
Back
Top
Base
One (V8) HERE
New One with fold away mount and larger speaker Note no memory card slot, this device is fitted with non expandable flash memory, for RDS-TMC you require the Mini USB style receiver.
Front
Back
Base
One (V9) HERE
New XL with fold away mount and larger speaker Note no memory card slot, this device is fitted with non expandable flash memory, for RDS-TMC you require the Mini USB style receiver.
Front
Back
Base
Edit Once - Mike Alder to remove the One from the the v9, and to add a note detailing what and where the v numbers come from (Thanks for the suggestion Andy)
Edit Second to add One v8/ v9 pictures (Thanks Darren)
PostPosted: Sun Feb 08, 2009 3:22 pm    Post subject: Reply with quote
mikealder wrote:
I still need some additional pictures to complete this list, if anyone can help with the v8/ v9 units it would complete the list for the time being
Mike, I've got both of them, I'll grab the images this afternoon.
PostPosted: Sun Feb 08, 2009 3:52 pm    Post subject: Reply with quote
Thanks, I will try and sort out the other images that have gone AWOL since I started to put this together a while ago, you never know users might finally be able to work out which One they have got! - Mike
PostPosted: Sun Feb 08, 2009 3:59 pm    Post subject: Reply with quote
A picture's worth a thousand words Very Happy
Can I just suggest you emphasise that the "V" numbers you are using are NOT what the UK retailers call them, but how TT "Home" refers to them when you connect the machine to the PC (and as you know TT themselves tend not to use the "v" numbers at all in their advertising or customer support literature).
In my list above and in all my posts, I've used small "v" for the Home IDs and big "V" for the retailers... not perfect by any means, but one small step. Wink
BTW... You've let a spurious "One" creep in at the end. The latest "XL" model is just that.... no "one" in the name at all.
PostPosted: Sun Feb 08, 2009 4:19 pm    Post subject: Reply with quote
Thanks for pointing that out Andy, I have altered the original post to reflect the changes you suggested and removed the "Extra One" - Mike
PostPosted: Sun Feb 08, 2009 4:26 pm    Post subject: Reply with quote
Images emailed to you.
Pocketgps
PostPosted: Sun Feb 08, 2009 8:11 pm    Post subject: Reply with quote
I have a ONE v4 EasyPort mount(v8).
TomTom also seem to refer to this model as the ONE 30 Series.
PostPosted: Sun Feb 08, 2009 10:17 pm    Post subject: Reply with quote
Andy_P (above) wrote:
Latest models with "easyport" mounts (referred to by TomTom's own website as BOTH the "30 series" or"22" models).
Typical TomTom! Laughing
Leofly
PostPosted: Mon Feb 09, 2009 11:06 am    Post subject: Reply with quote
mikealder, thanks! My unit is definitely one (V8).
Am I right, that TomTom does not use SiRF anymore?
Pocketgps
PostPosted: Thu Feb 12, 2009 12:29 am    Post subject: Reply with quote
I think that some of TT models use Broadcom Chips now.
Gee-Pee
PostPosted: Thu Feb 12, 2009 8:42 am    Post subject: Reply with quote
If you search the specs on the TT website, all it says is "Highly sensitive GPS chipset"
Gee-Pee
Leofly
PostPosted: Thu Feb 12, 2009 10:34 am    Post subject: Reply with quote
yes, Broadcom acquired Global Locate two years ago
(btw, CSR did the same with SiRF two days ago as well Smile)
Paul80
PostPosted: Wed May 06, 2009 12:27 pm    Post subject: Reply with quote
Just picked up what I think is a One V3 on the Box it said One Classic
Mind you Home also says the Latest Map Gurantee has expired as well, didn't know these were time limited
PostPosted: Wed May 06, 2009 1:21 pm    Post subject: Reply with quote
Yes, in yet another feat of confusion and obfuscation, TomTom have recently been re-selling the old "3rd Edition", badged as the "Classic".... even though the original 'One' is known as the Classic by everyone else!
As fir the Latest Map Guarantee, give them a call on 0845 161 0009 and ask them to assign the new map to your account (make sure it is a new account for this machine, not any previous account you might have).
h5djr
PostPosted: Wed May 06, 2009 4:41 pm    Post subject: Reply with quote
I just purchased a new 'TomTom ONE Classic Europe' and it says it's a 3rd edition (1Gb) (4N01.002) on the base. I used TomTom HOME version 2.6 and asked it to check that the maps were up to date. It checked and found there was a newer version and download and installed with no problems.
Dave R (h5djr)
TomTom XL + Audi A3 (with navigation)
