Pocket GPS World :: View topic - Brodit active mount plug
ben_e71
PostPosted: Sun Oct 19, 2008 8:51 pm    Post subject: Brodit active mount plug Reply with quote
Guys
the brodit active mount for a 730. Can I cut off the plug to hardwire it? Or does the plug do any fancy voltage stuff.....
PostPosted: Sun Oct 19, 2008 9:00 pm    Post subject: Reply with quote
If the plug connects to a 12 Volt power source it will contain a voltage regulator to control the voltage applied to the TomTom to 5V - cut the plug off and you will fry the PNA in a very short time.
Best bet is to purchase a ciggy cocket and wire that up in the vehicle, bury the whole lot behind the dash and plug the power lead into the socket, even consider some tape around the plug and socket to stop it parting company due to vibration, these sockets are easily available from Maplin/ Halfords etc - Mike
hoolahoops
PostPosted: Tue Oct 21, 2008 1:39 pm    Post subject: Reply with quote
If it's the same as my TT920T active mount, there will be a small black box into which the lead from the mount plugs into. There is then a fixed flying lead for you to connect somewhere to pick up the 12V.
As Mike said this "box" contains the regulation to go from 24/12V down to 5V, so you shouldn't try to remove it. I assume you bought the active mount (as opposed to one with a lead terminated in a cigarette lighter plug) as you intened to hire the wiring. You should aim to fix this box under the dash somewhere convenient. I used tie wraps to secure it to a convenient point and then tapped into the 12V used for the ciggy lighter.
Cheers - Kev
Kev
TT Go 950 Live. Fixed Brodit mount
Motorola Moto 4G
PostPosted: Tue Oct 21, 2008 3:05 pm    Post subject: Reply with quote
There are different types of mount, if it came with a cigarette lighter plug then the answer is 'No'. The alternative 12/24v fixed installation option has the reduction electronics in a black box and comes with bare wires and fuse.
Have you bought the mount already? If not then the Carcomm is the better x20/x30 mount IMO.
TomDavison
PostPosted: Fri Oct 31, 2008 5:50 pm    Post subject: Reply with quote
Not come across the carcomm mount. Having googled it, I can only find the basic mount. I have a brodit active mount for my One, and want something similar for my new 730. My car has the brodit car adaptor installed. Does the carcomm have an active mount, and can it be screwed to the brodit car adaptor? And since I haven't found any comparison reviews, why do you think it's better?
PostPosted: Fri Oct 31, 2008 5:52 pm    Post subject: Reply with quote
I have reviewed the CNM-167 here.
The later CNM-168 is identical but adds audio pass-thur. I have mine attached to a Brodit ProClip. Thoroughly recommend it.
I reviewed an earlier Carcomm x20 cradle here which has better images and compared to the Brodit solution reviewed here the Carcomm is better designed and the later models are smaller answering my only gripe.
The TMC pass-thru on the cradle works superbly allowing a very neat install.
22.053 (15 May 24)
