Pocket GPS World :: View topic - Need to understand how custom POIs work
nheather
PostPosted: Fri Aug 01, 2008 4:13 pm    Post subject: Need to understand how custom POIs work Reply with quote
Before I put POIs and indeed by the camera database here, I need to understand how the Custom POIs work on the Nuvi series.
I have the POI Loader.
I understand that you can't load custom POIs over a number of sessions. So if you install a set of files they will overwrite whatever Custom POis are on the machine at that time.
But there are some things I'm not sure of
1 - Out of the box the Garmin has quite a few POIs (services and cameras already). I can see the Cameras in the POI folder but the other services petrol, train stations etc are not. Does this mean that they are hard coded in the Sat Nav software.
2 - If I load petrol stations as custom POIs and the standard ones remain does this mean there will be duplicates in the system.
3 - If I load Petrol Stations as custom POIs where they appear in the 'My Location' when you click on the car icon. This is a really usueful function that shows Hospitals, Police Stations, Fuel and Roadside assist close to your current position.
Cheers,
Nigel
PaulB2005
PostPosted: Fri Aug 01, 2008 4:40 pm    Post subject: Reply with quote
They are coded into the map data and can't be removed, edited or updated.
Yes, but in two seperate areas. Also the icons are of different sizes so it's easy to tell the 2 apart.
No, they will be listed under the CustomPOIs in order of distance away from you.
auto_man
PostPosted: Sun Aug 03, 2008 1:38 pm    Post subject: Reply with quote
hello all,
me too i have just bought the Nuvi 660 and installed some poi's but i can't see them on the machine there are 8 icons, map, navigation, system, bluetooth, locale, proximity points, display and volume so where would i find any poi's already installed and the same with the safety cameras where do i find out this stuff, thank you
turboccc
PostPosted: Sun Aug 03, 2008 6:20 pm    Post subject: Reply with quote
On the 760, you can find them in the "Extras". Click on "Where-to" and scroll down to see "Extras". I am not exactly sure for the 660, but I guess Extras is there somewhere.
auto_man
PostPosted: Mon Aug 04, 2008 12:31 pm    Post subject: Reply with quote
yep turbo the extras icon is there but when i open it and look in it, it is empty
PaulB2005
PostPosted: Mon Aug 04, 2008 12:51 pm    Post subject: Reply with quote
auto_man - What did you install and how did you do it?
