Pocket GPS World :: View topic - TT GO 730T - Settings lost after reboot
MLF
PostPosted: Mon Jul 28, 2008 4:13 pm    Post subject: TT GO 730T - Settings lost after reboot Reply with quote
Hi, I've been losing settings after reboot, wondering if anyone has experienced the same and/or can help.
Something I should mention is that I loaded the Event Logger software from http://web.tiscali.it/macri/Event_Logger/. *This is not for the faint of heart.* I don't mean by that to discredit the authors, there are just some installation issues that can give you a bad time- they're documented, as is the workaround, but I still had a pretty bad time. Anyway, now that it's installed it does exactly what it says on the tin so I'm well pleased with it, but I do wonder if any of the problems I get are related to it being installed.
I can usually tell when this is going to happen because I can see that it has either started up or shut down inelegantly, but of course that doesn't tell me what settings I'm going to lose. Some examples are-
Voice selection - not so bad 'cos it tells you pretty quickly
County selection - for post codes etc
All favourites!!! WTF!!!
Speed camera alert sound!!
Setting to correct route based on traffic data!!!!
It's getting to the stage that I'm considering carrying around a little check list of the important settings to run through after an inelegant reboot! Has anyone else seen anything like this? I'm hoping that either I'll discover this is related to something I've done and can undo again, e.g. installing software or that a future NavCore release will fix it.
Thanks in advance.
Martin.
22.052 (08 May 24)
