yehudi Occasional Visitor
Posted: Sat Jun 21, 2008 12:05 pm Post subject: TMC reception in the North East |
Does anyone know which transmitters in the North East are transmitting TMC? My TomTom works fine in Leeds but gets nothing up here - Darlington. Even putting in my local Classic FM frequency manually 101.6 produces no results. |
Posted: Sat Jun 21, 2008 12:23 pm Post subject: |
Welcome to the forum, have a read through FAQ #9 which can be found by clicking Here it is a little out of date but will explain how to use the POI file I have sent to you on the device in order to work out the best frequency relative to location.
If the rain doesn't stop I might even edit the RDS-TMC guide to bring it up to date later today, most of it is still OK, just the way certain information is no longer displayed on the device - Mike |
The Rudd Regular Visitor
Joined: Apr 18, 2006 Posts: 121 Location: Newcastle upon Tyne
Posted: Sat Jun 21, 2008 1:09 pm Post subject: TMC Up North |
Hi there
I am not an expert on TMC but I know that the two nearest here near Newcastle are
(a) On the A69 at Newton
(b) There is another one In Fenham Newcastle.
Jerrry |
Posted: Sat Jun 21, 2008 3:22 pm Post subject: |
Mike,
Many thanks for your help. I've loaded your file into my TT & now know where my nearest TXs are. However, even manual tuning produces no better result. Looks like I'm stuck with no reception up here.
I knew there was a good reason to work in West Yorkshire!! |
Posted: Sat Jun 21, 2008 3:31 pm Post subject: |
Make sure the aerial wire is at least 5CM away from the edge of your windscreen, there are other ways to increase signal reception by connecting the aerial wire to the car aerial or even a dedicated aerial on the outside of the vehicle. These home made work arounds are covered in some detail in a number of posts within the forum.
What car is it you have the device fitted in, some have heat reflective windscreens (athermic glass) which attenuates the RF signal very effectively.
I have also found the device takes a while to lock on to the signal when first used, once it has found the correct signal frequency subsequent lock on times are much faster (the device stores the last know frequency that it used in one of the files on the unit) - Mike |
falkirk81 Pocket GPS Verifier
Joined: Jul 07, 2006 Posts: 1649 Location: Newcastle, England, UK
Posted: Wed Jun 25, 2008 11:26 pm Post subject: |
I live and work in the newcastle area and did get patchy reception with the original RDS-TMC cable and version 7 tomtom software. But recently i upgraded (legally) to the version 8 tomtom software and got the most up to date RDS-TMC cable and now have NO issues around newcastle/gateshead and up north to Amble! Any questions feel free to respond in this forum and i`ll gladly give you any advice you need! _________________ Tomtom GO 1005 LIVE
iPhone 12 |
