liketohelp Occasional Visitor
Posted: Mon Jun 16, 2008 11:17 pm Post subject: Drivesmart-Speed Too Fast |
I have only just joined this site and i have downloaded the last two PGPSW updates for the DS.My problem is that when i load up the PGPSW database onto the DS using the client loader version 1.5 as an extra database,although the DS recognises the camera's i always get the message Speed Too Fast if i am doing over 19mph when i approach the camera,regardless if the actual speed limit is 30 or 40 etc.If i erase the PGPSW database from the DS then everything works fine again.Can anyone help |
Posted: Mon Jun 16, 2008 11:27 pm Post subject: |
19 warning in a 30 limit...
With Garmin units this happens when you select a MPH database but set the uploading software to KPH....
I'm not overly familiar with the DS system so all i can offer is you need to make sure the software is loading the database in the unit using MPH and not KPH. |
Mr_T Lifetime Member
Posted: Tue Jun 17, 2008 12:51 am Post subject: |
How does the DS behave if you load a DS provided database? _________________ Drive-Smart-01, DS Pulse Master
and iPhone 3GS 16GB 3.1.2 & Win-XP |
Posted: Tue Jun 17, 2008 1:16 am Post subject: |
PaulB2005 wrote: | 19 warning in a 30 limit...
You cannot choose MPH or KPH when uploading the PGPSW database you can only upload the file
If i load the DS provided Database the unit works fine |
Posted: Tue Jun 17, 2008 1:17 am Post subject: |
Mr_T wrote: | How does the DS behave if you load a DS provided database? |
The DS works fine if i load a DS provided Database |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15142 Location: Bradford, West Yorkshire
Posted: Tue Jun 17, 2008 1:59 am Post subject: |
how about just using the PGPSW database rather than using it as an 'extra' database?
have you edited the file in anyway? the kph / mph is a value in the file itself - the 4th column should be '1' which is mph (kph = 0)
-0,19830;51,84749;70;1;9;202 = lon ; lat ; speed ; mph/kph ; camera type ; heading
MaFt |
Posted: Tue Jun 17, 2008 10:22 am Post subject: |
MaFt wrote: | how about just using the PGPSW database rather than using it as an 'extra' database?
MaFt |
I cannot use just the PGPSW database because i am using the drivesmart loader 1.5.0 client version prog which does not allow you to use the PGPSW database as the main database nor does it allow you to delete the existing DS main database.Having looked at the ds instructions on the site i can see that there is a DS loader 1.4.16 Private Version Prog which does allow you to do this but i havn't got a copy and don't know how to get one.
I have followed the DS instructions option1 that are on the site and not modifyed the file in any way |
Posted: Tue Jun 17, 2008 11:12 am Post subject: |
someone somewhere here will have it and likely email you a copy. we used to host it but DS threatened us with legal action so it has now gone...
ps - i'm guessing v1.5 is the 'new' version for the new firmware for the DS's? if so then we were warned about possible incompatibilities with it... |
GJF Frequent Visitor
Posted: Tue Jun 17, 2008 11:55 am Post subject: |
MaFt wrote: | someone somewhere here will have it and likely email you a copy.................... |
Quote: | ps - i'm guessing v1.5 is the 'new' version for the new firmware for the DS's? if so then we were warned about possible incompatibilities with it... |
Quote: | I cannot use just the PGPSW database because i am using the drivesmart loader 1.5.0 client version prog which does not allow you to use the PGPSW database as the main database nor does it allow you to delete the existing DS main database..... |
I wonder if this new 1.5.0 s/ware is designed to set the DS, so that it can't be removed once installed? _________________ TomTom Go 60
Garmin Nüvi 660, Firmware v4.90
Drive-Smart GPS with Loader v1.4.16
HTC Advantage X7500 MS 6.1 Tchart Speed Sentry
Satmap Active 10, Software v1.16
Fuzion 32 HUD Bluetooth GPS receiver |
Posted: Tue Jun 17, 2008 1:58 pm Post subject: |
MaFt wrote: | someone somewhere here will have it and likely email you a copy. we used to host it but DS threatened us with legal action so it has now gone...
Thanks for the advice so if anybody has a copy of the DRIVESMART LOADER v 1.4.16(PRIVATE VERSION) PROG i would be grateful if you could send it to me.At least i could then see if it sorts out my problem |
Posted: Tue Jun 17, 2008 4:02 pm Post subject: |
liketohelp, I left a message in your PM box.
EDIT:
Sorry just looked in the PM's i thought i sent you a message but it doesn't seem to be there, I've lost it!
New message there for you. _________________ TomTom Go 60
Posted: Wed Jun 18, 2008 8:02 pm Post subject: Drivesmart Loader 1.4.16 |
GJF wrote: | MaFt wrote: | someone somewhere here will have it and likely email you a copy.................... |
I wonder if this new 1.5.0 s/ware is designed to set the DS, so that it can't be removed once installed? |
Does anybody have the Drivesmart Loader 1.4.16 Private Version Prog because i downloaded the new DS Database today and as usual it is missing cameras so i would like to use the PGPSW DATABASE instead |
Posted: Wed Jun 18, 2008 10:10 pm Post subject: |
GJF wrote: | liketohelp, I left a message in your PM box.
EDIT:
New message there for you. |
GJF
Have replied to your PM but not heard from you |
Posted: Thu Jun 19, 2008 9:20 am Post subject: |
Hi liketohelp,
I did send it, but the e-mail was returned.
I have now received your second e-mail sent and have tried that today.
Sorry, but i'm not using the computer at the moment from 5pm to 9am as over dosed in the day, so having the night off - I'm only available during the day time. _________________ TomTom Go 60
Posted: Thu Jun 19, 2008 2:04 pm Post subject: |
Sorry liketohelp but your second e-mail is not getting through to you either.
Quote: | The original message was received at Thu, 19 Jun 2008 09:09:53 +0100 (BST)
from 7*-**-1**-2**.no-dns-yet.enta.net [7*.3*.1**.2**]
----- Transcript of session follows -----
*** 4.4.1 reply: read error from mail-in.freeserve.com.
p*****(at)**********.freeserve.co.uk... Deferred: Operation timed out with mail-in.freeserve.com.
Warning: message still undelivered after 4 hours
Will keep trying until message is 5 days old |
Maybe easier to PM me your address so i can send it. _________________ TomTom Go 60
