Pocket GPS World :: View topic - 920 restarting
920 restarting
hebjp
PostPosted: Mon May 12, 2008 5:55 pm    Post subject: 920 restarting Reply with quote
When i switch the unit off it shuts off then about 15 seconds later it swiches it self back on.
When it comes back on it's as if i have just disconnected from the computer ie the bar that runs across the screen then it starts as normal
If i then press the off button again it switches off and stays off
PostPosted: Mon May 12, 2008 5:57 pm    Post subject: Reply with quote
Try the Route Clear button to remove any remaining planned route and it should stop this silly behaviour, otherwise a prod of the reset switch on the underside of the device might be in order, you won't loose any data trying either option - Mike
hebjp
PostPosted: Mon May 12, 2008 8:54 pm    Post subject: Reply with quote
Had no route to clear but have tried the reset
Switched on and off a couple of times and so far so good
Thank you for the advice
22.053 (15 May 24)
