gabbyevs Regular Visitor
Posted: Sun Feb 17, 2008 7:29 pm Post subject: |
while im here wot do you do about camera thats used to be somewhere but have now gone and its still showing up on the database? |
Posted: Sun Feb 17, 2008 7:56 pm Post subject: |
Quote: | while im here wot do you do about camera thats used to be somewhere but have now gone and its still showing up on the database? |
You can submit a removal request in the yellow form on this page. Just make sure you change the action to "Remove Existing Camera" |
Darren Frequent Visitor
Posted: Sun Feb 17, 2008 8:18 pm Post subject: |
gabbyevs wrote: | while im here wot do you do about camera thats used to be somewhere but have now gone and its still showing up on the database? |
What is the camera ID? _________________ Darren Griffin |
Posted: Sun Feb 17, 2008 8:45 pm Post subject: |
it says on your database its been removed but it still shows on my nav |
Andy_P Pocket GPS Moderator
Posted: Mon Feb 18, 2008 3:59 pm Post subject: |
In which case you need to download the latest database and overwrite the files that you are using with the latest ones. You should be doing that every 2 weeks or so.
To be informed whenever a new version is released, got to this topic:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=39307, scroll to the bottom of the page and click on "Watch this topic for replies". |
Posted: Mon Feb 18, 2008 8:42 pm Post subject: |
how do i overwrite old files? |
Posted: Mon Feb 18, 2008 9:07 pm Post subject: |
If i read the thread correctly you are using a Nuvi?
If so, just use POILoader to load the new database and it'll delete the old one for you.
However if you have other POIs for fuel etc then you need to make sure you load those too. POILoader wipes out all third party POIs (including the Safety Cameras) before you load the next lot. If you haven't already done so, make a folder on your Mac called My POIs, put all your POIs in it including the safety cameras and upload them using POILoader.
Each month download the same version of the database as before and extract it into the POI folder, overwriting the old files in the My POIs folder. Then upload ALL your POIs using POILoader. |
GPS_fan Pocket GPS Moderator
Joined: Jan 04, 2007 Posts: 2789 Location: Hampshire, UK
Posted: Fri Feb 22, 2008 8:49 am Post subject: |
This subject crops up time and again.
Might it be worth adding a sticky for downloading the database and using StuffitExpander to unzip it for installation?
I've been using Mac since StuffitExpander was included in Mac OS and have 'grown up' with it. However, it appears that newcomers to Mac (where StuffitExpander is no longer included in Mac OS X) may not be aware of this application and thus encounter difficulties with the PGPSW database. _________________ Andy
PocketGPSWorld.com supports Help for Heroes - Read here |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15145 Location: Bradford, West Yorkshire
Posted: Fri Feb 22, 2008 10:44 am Post subject: |
i've added some code to the download area now so that if you are a mac user then you should have a brief description of how to exract the files on a mac.
can people test it please?! i can confirm that it is NOT shown on windows but don't have a mac to test if it shows when it should! |
Posted: Fri Feb 22, 2008 10:48 am Post subject: |
Nice, works fine here using Safari and Firefox. _________________ Darren Griffin |
Posted: Fri Feb 22, 2008 10:59 am Post subject: |
I've just tried it on an older Mac with 10.4 and Safari 2.0 and it gave a 'decompression failed' error.
I guess that Darren might be using 10.5 and Safari 3 (or later)...I'll try installing 10.5 onto this lovely machine and see if this overcomes the problem and I'll let you know, so it might give a clue _________________ Andy
Posted: Fri Feb 22, 2008 11:00 am Post subject: |
where abouts is it on the download section i cant seem to find it |
Posted: Fri Feb 22, 2008 11:07 am Post subject: |
GPS_fan wrote: | I've just tried it on an older Mac with 10.4 and Safari 2.0 and it gave a 'decompression failed' error. |
It doesn't change this issue, just alerts Mac users that they need Stuffit. _________________ Darren Griffin |
Posted: Fri Feb 22, 2008 11:09 am Post subject: |
gabbyevs wrote: | where abouts is it on the download section i cant seem to find it |
Once you select your download type you will see this warning:
Posted: Fri Feb 22, 2008 1:23 pm Post subject: |
Yes I get the "Numpty of the Week" award
I realised my mistake as soon as I started the installation of 10.5
Anyway, I've done a little research and can confirm that it works with:
OS 10.5 and Safari 3.0
OS 10.4 and Safari 2.0
OS 10.3 and Safari 1.1
I haven't gone to the trouble of installing Firefox several times, but Darren has tested Firefox and if Safari works with these versions of Mac OS, it's probably safe to assume that Firefox will also work.
Hopefully, this extra info will make amends for my numptyness _________________ Andy
