peasemore Lifetime Member
Posted: Mon Aug 20, 2007 8:04 am Post subject: MyGuide 4200 M4 J10 speed camera odd behaviour;UPdate |
Any ideas as to what causes a speed camera warning which comes on before J10 of M4 when heading East, and stays on for several miles.
Additionally lower text on box instead of showing how many yards to next camera is showing speeds of 150mph+??
SAME HAPPENS west bound; I have posted image of what I see here.
http://www.peasemore.plus.com/CAMS.HTM
Links fixed by PaulB2005 _________________ Gel
Lifetime Member Thames Valley, Berkshire, UK
Mazda CX-5 built in SatNav- not sure if TT or not. Garmin NUVI in reserve. |
Posted: Thu Aug 30, 2007 8:07 am Post subject: Different format database |
Downloaded latest & alternative format database, but problem still there From just before J10 M4 E the odd camera alert stays on and in alarm for 10 miles! _________________ Gel
Posted: Thu Aug 30, 2007 9:30 am Post subject: |
I can't tell from the picture but does it indicate which camera is setting it off?
I have a mobile camera near me that continues to alert even when you've passed it or if you approach the road it's on from a side road and turn in the opposite direction to the cameras location it still alerts you for another half a mile or so.... |
Posted: Thu Aug 30, 2007 12:50 pm Post subject: WHICH CAMERA |
Hard to see when driving, but lower speed reading changes, but all above 125mph, which I ain't doing on M4 in morning!!!
There are none on M/way at this point; specs cameras are around
Reading junctions. _________________ Gel
Posted: Wed Sep 26, 2007 6:12 pm Post subject: Still annoying |
I've loaded latest d/base Darren, but my unit still screams at me for miles after these cameras; is it possible there's something odd about way they're listed on GPS D/base??
I get the grief west and eastbound.
For example 1/2 mile before J11 Westbound, unit alarms correctly, then doesn't clear and stays on for 1.5 miles afterwards in alarm .
Again after the specs Westbound M4, about 1/2 mile before Reading Servs, which is indicated correctly UP to the SPECS (50mph), but as per image posted I get audible alarm/icon on display (from this specs as soon as I pass) for 7 miles after J 12!! _________________ Gel
alix776 Pocket GPS Moderator
Posted: Wed Sep 26, 2007 6:23 pm Post subject: |
is a specs camera and is a know issue with Igo _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Wed Sep 26, 2007 7:31 pm Post subject: IGO/MY Guide |
Thanks for that. _________________ Gel
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15144 Location: Bradford, West Yorkshire
Posted: Wed Sep 26, 2007 10:31 pm Post subject: |
alix beat me to it... there are issues with specs and average speed in the igo software (which myguide uses).
i knw recently someone posted some code you can add to some system files that will fix it? i THINK it was M8TJT but i may be mistaken...
MaFt |
Posted: Wed Sep 26, 2007 10:43 pm Post subject: Fix |
MaFt a beginners guide to how to load would be valued _________________ Gel
Posted: Wed Sep 26, 2007 11:28 pm Post subject: Re: Fix |
peasemore wrote: | MaFt a beginners guide to how to load would be valued |
how to load what? |
Posted: Thu Sep 27, 2007 7:20 am Post subject: Re: Fix |
MaFt wrote: | peasemore wrote: | MaFt a beginners guide to how to load would be valued |
how to load what? |
Posted: Thu Sep 27, 2007 2:42 pm Post subject: Link |
Many thanks
However, that seems to relate to metric/mph issue not
the fact that some specs cameras have odd effect when I drive past.
Mine reads in mph just fine.
think link should be
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=54996#54996 _________________ Gel
Posted: Thu Feb 14, 2008 11:01 pm Post subject: Jammed on cameras on MyGuide 4200 |
I wish the manufacturers would post a s/ware fix for this annoyance.
Going W Bound M4, from the specs just past Reading Services* the satnav stays in alarm mode, (missing the final specs (3rd of 3) at J12), and stays in that state when it finally clears at J13, 12 miles on
Switching on and off between the junctions doesn't cure either.
I assume it's nothing odd on the database entry.
*Specs in question
SPECS:40794@50, _________________ Gel
