davidrose Occasional Visitor
Posted: Tue Mar 02, 2004 6:36 pm Post subject: Mitac 338 + RS232 Smart GPS Antenna ? |
I am considering the Mitac 338 - anyone had experience with it?
I notice that Mitac 338 comes bundled with TomTom2 + "TomTom GPS
smart antenna"(Is it the Leadtek 9532?? which is a GPS smart antenna
with RS232)
Therefore they must be compatible - so either there is RS232 on the PDA
(although Mitac sales tell me otherwise) serial connector OR a USB to
RS232 conversion goes on in the connecting cables.
If it is USB compatible
When the Mitac 338 normally connects to a PC it becomes the "USB client" -
I presume when it connectors to a GPS sensor it becomes a "USB host"
would this be correct ?
David |
Pc-Mobile Frequent Visitor
Joined: 26/10/2002 10:38:36 Posts: 789 Location: Hong Kong
Posted: Wed Mar 03, 2004 10:24 am Post subject: |
No.
GPS use serial port and has nothing to do with USB.
Mio 338 has a serial port, it is simple as that.
It also has a USB port (client) so is able to connect to a host (PC) _________________ Pc-Mobile
http://pc-mobile.net/gps.htm |
Posted: Wed Mar 03, 2004 10:35 am Post subject: |
As Mio 338 has a serial port, and GPS is a serial device, the 2 can communicate with each other with the right connecting cable.
On the other hand, a USB host device can only communicate with a client.
A host cannot connect to another host, nor a client to a client.
The USB port on the Mio is a client, A USB GPS is also a client, so you cannot connect a USB GPS (or any USB client device).
Some PDAs now have both USB host and client ports so it is possible to connect a USB client device (GPS/Harddisk) with the right driver (yes driver is needed).
Is that a bit confusing? _________________ Pc-Mobile
Posted: Tue Mar 09, 2004 12:41 pm Post subject: |
Thanks Pc-Mobile
I will be in touch to get a cable!!! |
