Pocket GPS World :: View topic - Mio 168 with TT5.1 - how to display speed alert on Mio168
thewarrior
PostPosted: Wed Jan 02, 2008 12:44 pm    Post subject: Mio 168 with TT5.1 - how to display speed alert on Mio168 Reply with quote
Hi All,
Sorry if this is a daft question.
When approaching a speed camera, the Speed Camera Icon is displayed, the camera alert sounds, but it does not display the camera speed eg 30MPH
I have run through my menus, but l cant find where it states 'display camera speed'.... l'm pretty sure, l had this setup before.
So, if you can point me in the right direction, that would be very much appreciated
thanks
PostPosted: Wed Jan 02, 2008 12:52 pm    Post subject: Reply with quote
I assume you are using the Pocket GPS World Speed Camera database? - if so I would remove the current camera files from your device, download and install the Speed Zoned database version and set that up, this one will offer you the type of camera and the speed. If you also use the spoken alert file packs from THIS Page the device will also tell verbally the type of camera and associated speed - Mike
thewarrior
PostPosted: Wed Jan 02, 2008 1:52 pm    Post subject: Reply with quote
Hi Mike,
thanks for your response
I have loaded the single consolidated file from the speed camera database. But kept the other old ones as well...
I will have to look into the Speed Zoned database.
I assume l have downloaded the wrong file then from the wrong database. I thought there would be an easy way of displaying the camera speed, when approaching a camera
cheers,
PostPosted: Wed Jan 02, 2008 1:57 pm    Post subject: Reply with quote
The data is identical for each of the different downloads, the only bit that differs is how the file set is split up
Single File - All camera types and speed in a single POI file.
Consolidated by Type - Cameras are supplied in a file for EACH type of camera
Speed Zoned - The most comprehensive, the data is split up into individual files where each file will contain a single camera type at a specific speed.
It does take a little longer to set up the speed zoned warnings due to the quantity of files, but it is well worth the extra little bit of effort - Mike
thewarrior
PostPosted: Wed Jan 02, 2008 2:11 pm    Post subject: Reply with quote
thanks for the info Mike,
thanks very much appreciated
aj2052
PostPosted: Thu Jan 03, 2008 1:55 am    Post subject: Reply with quote
Just to add to mikes comment, even tho the zoned set take longer to set up initially they dont need altering everytime you update, so in the long run they are possibly the best.
22.053 (15 May 24)
