1952kev Lifetime Member
Joined: Dec 16, 2005 Posts: 148 Location: Grantham , Lincs
Posted: Mon Dec 03, 2007 12:25 pm Post subject: TT1 v1 - USB charging through HOME? |
Only downloaded HOME recently to get new map installed.
Just started using it to plan a route this morning and noticed the battery indicator on the ONE on my PC screen was showing as "charging"
I didn't have it connected to the charger so can I assume that the One now charges via the USB lead..........................or is it just wishful thinking? |
Andy_P Pocket GPS Moderator
Posted: Mon Dec 03, 2007 12:37 pm Post subject: |
No, the on-screen "virtual TomTom in Home just "looks pretty". It tells several lies. Another is the satellite strengh bars wiggle up and down happliy, even when you have no real satellite signal at all. It also usuaally shows the wrong software version, and on the Go720 the real menus are significantly different. |
franb Banned
Posted: Mon Dec 03, 2007 1:01 pm Post subject: Re: TT1 v1 - USB charging through HOME? |
1952kev wrote: | Only downloaded HOME recently to get new map installed.
If your unit is connected to your PC via the USB lead it will be charging (slowly) whether you're running TTHome or not. |
Posted: Mon Dec 03, 2007 1:20 pm Post subject: |
NOT on a One Original, Franb!
USB charging only came in on the One "New Edition" (a.k.a "2nd Edition") if I remember correctly.
The way to check is to look at the car charger. If it has a USB plug on it, then you can also charge via the PC (but maybe more slowly)
If the car charger has a D.C power plug, then the unit will only charge via the same socket. |
Posted: Mon Dec 03, 2007 2:28 pm Post subject: |
Thanks Andy. I had a feeling Home was using a bit of artistic licence as far as what was being displayed on my PC. |
franb Banned
Posted: Mon Dec 03, 2007 2:42 pm Post subject: |
Andy_P2002 wrote: | NOT on a One Original, Franb!
Yup, you're right but assumed 1952kev was talking about a V2/3/4 etc
(should have read the subject line!) |
