WeeHappyPixie Occasional Visitor
Posted: Thu Nov 29, 2007 9:52 am Post subject: 910 with OGG Files (7x) |
First, I apologise if this has been asked before.
I have updated to the new v7 software today and updated my maps to 710.
Problem I have is with the PocketGPS safety camera warnings sound files.
I have the OGG files in the same folder however when I go into manage POI then warn when near POI to setup the warning, I can select the distance then I'm asked if I want to use text to speech or sound file so I click on sound file and it jumps back to the distance.
Keep going round in a loop and I need to cancel it.
Is there any way round this guys n gals.
Off to Hull on Sat and I dont feel like giving my hard earned £££ to Humberside police. Darn cameras everywhere there.
Thanks in advance
John |
Darren Frequent Visitor
Posted: Thu Nov 29, 2007 10:25 am Post subject: |
If you're sure you have correctly installed the OGG files and that an OGG file exists in the same folder and with the same name then try a soft reset before configuring the alerts.
The soft reset button is well concealed underneath near the docking connector and you will need a paperclip or pin to insert into the hole and reset it. _________________ Darren Griffin |
Posted: Thu Nov 29, 2007 11:04 am Post subject: |
Hi Darren,
Thanks for the quick reply. I have already done a soft reset.
The OGG files are the exact same name as the poi. I have 3 files for each speed, ie pocketgps_uk_gatso_20.poi, pocketgps_uk_gatso_20.bmp and pocketgps_uk_gatso_20.ogg
Everything worked OK with V6 but not with V7. I have since tried adding one poi with ogg to my partners tomtom 1 with v7 and again go round in circles.
Thanks again.
John |
Flack Regular Visitor
Posted: Thu Nov 29, 2007 11:12 am Post subject: |
WeeHappyPixie wrote: | Hi Darren,
Thanks again.
John |
John
pocketgps_uk_gatso_20.poi this file should be pocketgps_uk_gatso_20.ov2 and not .poi your TT is looking for this file and can't find it. try and rename it and it should work.
Flack |
Posted: Thu Nov 29, 2007 11:18 am Post subject: |
I'm not sure that's the issue because if it was, he wouldn't get as far as being able to choose an alert _________________ Darren Griffin |
Oldboy Pocket GPS Moderator
Posted: Thu Nov 29, 2007 12:20 pm Post subject: Re: 910 with OGG Files (7x) |
WeeHappyPixie wrote: | then I'm asked if I want to use text to speech or sound file | I didn't know 710 had Text to Speech capability.
On the 910 after the Distance Setting I get a Screen with 4 Options; Full, or Brief, spoken warning, Sound Effect and Type in your own warning.
Sound Effect uses the OGG Files. _________________ Richard
Posted: Thu Nov 29, 2007 12:39 pm Post subject: |
That's a good point, the 710 doesn't have TTS? _________________ Darren Griffin |
Andy_P Pocket GPS Moderator
Posted: Thu Nov 29, 2007 12:45 pm Post subject: |
Oldboy and Darren: it IS a 910, the "710" he mentioned was referring to the maps...
WeeHappyPixie:OK, I'm not sure why you are getting this, but here's a way round it.
It hasn't been announced yet as yet another way of doing the audio alerts, but it should work on a 910 with v7 software.
Take the ogg files OUT of the map folder
There should be a folder called "sounds" on the TomTom now.. put them in there instead (you can even leave them in a folder if you like.
Now, when you go to the "warn when near" set-up, select "sound effect" and scroll down. All the new ogg files should be there, and you can even click on each and listen to it before you choose it.
The only irritation at the moment is that the files get listed in a strange order, and because they are all named "PocketGPS....." the useful part of the names are not shown on screen, so you have to do a bit of digging to find the one you want.
Try it and see how it works for you. |
Posted: Thu Nov 29, 2007 12:48 pm Post subject: |
Andy_P2002 wrote: | Oldboy and Darren: it IS a 910, the "710" he mentioned was referring to the maps... |
Dang ... Of course I blame Oldboy _________________ Darren Griffin |
Posted: Thu Nov 29, 2007 12:49 pm Post subject: |
Darren wrote: | Andy_P2002 wrote: | Oldboy and Darren: it IS a 910, the "710" he mentioned was referring to the maps... |
Dang ... Of course I blame Oldboy | Everybody else does. Why should you be different. _________________ Richard
Posted: Thu Nov 29, 2007 3:40 pm Post subject: |
My mistake guys, the file is a .ov2 file. i was reading the description when i was creating the post.
My TomTom is a GO 910. My maps are 710.1561
John |
Posted: Thu Nov 29, 2007 5:48 pm Post subject: |
WeeHappyPixie wrote: | My mistake guys, the file is a .ov2 file. i was reading the description when i was creating the post.
John |
My 910 work just like Andy says, if you put all your oggs in the map folder then go to the warn when near as long as the ogg file is exactly the same name as the poi file and you have use sound effect set to yes or ticked it should work ok.
Flack |
Posted: Thu Nov 29, 2007 9:56 pm Post subject: |
John |
Have you tried my alternative method? |
Posted: Fri Nov 30, 2007 8:49 am Post subject: |
Andy_P2002 wrote: | WeeHappyPixie wrote: | My mistake guys, the file is a .ov2 file. i was reading the description when i was creating the post.
John |
Yipeee.....
Thanks Andy, Worked like a charm. As you said though, bit of a nightmare getting right file due to length of filename so I created a little batch file to rename ann the ov2 files to Gatso_20 etc just to shorten them.
Well impressed with the new sounds folder. Thanks again...
John |
vibeone Lifetime Member
Posted: Fri Nov 30, 2007 9:38 am Post subject: |
its a bit odd that they don't work in the normal manner though - although there have been problems reported, it works for most other people.
just remember that the ogg files system is a little bugged at present, on selecting sound effect, with ogg file present youll get a screen saying "Is this the sound you want to use" - ALWAYS PRESS YES. hehe... No will lock the tomtom and require a reboot. |
