Akshay123 Occasional Visitor
Posted: Mon Nov 19, 2007 11:48 am Post subject: SD card reading issues |
Hi I recently bought a TomTom 520 online from Dixons but I can't get it to read from my 2GB SD card! I stored some mp3's and photos on there but the device doesn't acknowledge that there is an SD card in the slot. My assumption was that if you selcted media/juke box that any media content on the SD card would have been picked up! Is this a common problem or should I take it into a store?? |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Mon Nov 19, 2007 1:12 pm Post subject: |
The x20 devices seem to be fussy about which cards they'll recognise.
See this thread. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21 |
Andy_P Pocket GPS Moderator
Posted: Mon Nov 19, 2007 2:33 pm Post subject: |
You are right in your assumption that the TomTom should automatically see the extra content on a card if one is present... BUT the music files need to be in a folder called "mp3" (no quotes) and the photos need to be in one called "photos", otherwise they won't be found.
There are folders with the same names on the internal memory too. |
Posted: Mon Nov 19, 2007 2:45 pm Post subject: |
Thanks Andy, I'll give that a try later on and see if it resolves the issue. I suppose it makes sense though as the internal memory has the specific folders already as you mentioned, so obviously the TT is set-up to read from only designated folder names.
Does anyone know if its also possible to play video content on the 520, and if so, how? Just an idea. |
Posted: Mon Nov 19, 2007 3:07 pm Post subject: |
You'll now be sorted if you hadn't done that so far.
For video... search "mobilnova".
Here's one mention of it. |
Posted: Tue Nov 20, 2007 7:58 am Post subject: |
Thanks guys, I sorted the problem by creating folders like you mentioned, and also downloaded a trial of modilnova to try out the video playback. While not being DVD quality, I was surprised at how well the picture looked! Just need the full version now!
The only thing now is that I can't get rid of the music symbol on the screen when not playing any mp3's - how do I get rid of it?
Also what is the maximum size card that can be supported on the 520? |
Posted: Tue Nov 20, 2007 8:56 am Post subject: |
I am running an 8GB SDHC card in my 720 which is working very well, I would expect the same card to work in the 520 - Mike |
Posted: Tue Nov 20, 2007 11:52 am Post subject: |
Akshay123 wrote: |
This is a small bug on models running Navcore 7 "light" (you have to switch it off in the Jukebox's own preferences), but on a 520 you should have a full setup for "QuickMenu" in the "Change preferences" menus, where you can choose any of about a dozen items to put there.
Note that when you connect to Home and use the "virtual" on-scren TomTom, it messes your choices up and you have to reset them. |
Posted: Tue Nov 20, 2007 11:08 pm Post subject: |
Thanks for that Andy, got it all sorted now and also have a full version of mobilnova so been watching Prison break series 3! All I need now is a reliable 8gb card that will work on my 520! |
TerryUK Occasional Visitor
Joined: Dec 29, 2005 Posts: 6 Location: West Midlands
Posted: Wed Nov 21, 2007 9:42 am Post subject: |
mikealder wrote: | I am running an 8GB SDHC card in my 720 which is working very well |
Hi Mike. At the moment on my 720 I am using a Kingston 1GB card which is working ok for the mp3 file although audiobooks will still only work from the internal memory. I would like to have more memory available for mp3 selection and wondered if you could say which SDHC card it is that you are using.Thank you. |
Posted: Wed Nov 21, 2007 10:50 am Post subject: |
TerryUK wrote: | I am using a Kingston 1GB card which is working ok for the mp3 file although audiobooks will still only work from the internal memory. |
That issue was fixed with v7.210 software for the Go520 and 720 - released on 6th Nov 2007. So long as the audiobooks are inside a folder called "audiobooks" on the card, it should now find them.
If you connect to Home (v2.1), v7.210 should be offered to you when you click on "update my Device" |
Posted: Wed Nov 21, 2007 12:54 pm Post subject: |
Andy_P2002 wrote: |
Thanks Andy I will try the update when I get back home tonight |
Posted: Wed Nov 21, 2007 1:38 pm Post subject: |
In my (future) defence, I did say "should..." |
shire29 Occasional Visitor
Posted: Wed Nov 21, 2007 6:49 pm Post subject: re |
am having similar problems with my SD cards, tried 2 and get the same result.
Weird thing is if I connect to my PC I can see the SD card through the 520 PC connection. 520 memory comes up as drive H and the SD card drive I so i know it's there and working.
But why doesn't the 520 read from it.
I tried the folders with no luck.
The other odd thing is that the 520 won't turn on with the memory cards inserted. On boot up it shows an icon with a red X on it and then shuts down. It will only fully start when I remove the card.
Any suggestions ? please.
Cheers, Blair |
Posted: Wed Nov 21, 2007 8:27 pm Post subject: |
The card I am using in my 720 (8GB SDHC) is one of These - Mike |
