Wistow Occasional Visitor
Posted: Fri Aug 31, 2007 12:21 am Post subject: Alert Information in POI's |
Garmin Nuvi610, all updated using the webupdater version numbers unknown
I have created my own POI's for the shops I look after
using the structure of -4.17597,55.760874,"EAST KILBRIDE 01355 236342" in a csv file.
The POI loader wors fine and the POI's are visable in custom POI's however when selecting a POI the screen displays
"Alert Information:"
"Distance: 1319ft"
"Speed: 1mph"
This has not happened with any other csv POI files I have loaded, how can I remove the Alert Information details
Is it possible to edit the Favourites on the PC
Thanks Graham |
Posted: Fri Aug 31, 2007 7:10 am Post subject: |
Hi and welcome.
Quote: | Is it possible to edit the Favourites on the PC |
You can edit, backup ands restore Favourites with EasyGps www.easygps.com
Quote: | how can I remove the Alert Information details |
Did you load the POIs using Manual or Express method? |
Posted: Fri Aug 31, 2007 6:29 pm Post subject: |
Thanks I will try EasyGps
The POI's were loaded with the Express method. I loaded them in exactly the same way as the other POI's.
I tried copying them to a new cav file but no difference
Graham |
PhilHornby Frequent Visitor
Joined: Dec 07, 2006 Posts: 563 Location: North Devon
Posted: Tue Sep 04, 2007 3:19 pm Post subject: Re: Alert Information in POI's |
Wistow wrote: | The POI loader wors fine and the POI's are visable in custom POI's however when selecting a POI the screen displays
"Distance: 1319ft"
"Speed: 1mph"
You must have created a file whose name contains one of Garmin's reserved words, or more likely, you've got a number "1" in the name.
POI Loader applies some "Eye of Toad, Leg of Newt" logic and decides that you want all POI's to have a 1 mph Speed Alert :-) |
Posted: Tue Sep 04, 2007 4:54 pm Post subject: |
Thanks Phil, yes the file was called region 1
Graham |
