Pocket GPS World :: View topic - Adding POI's
Adding POI's
Zondaf
PostPosted: Mon Jul 23, 2007 6:29 pm    Post subject: Adding POI's Reply with quote
When u add POI's does this overwrite the ones already on there or just add to them?
PostPosted: Mon Jul 23, 2007 6:31 pm    Post subject: Reply with quote
That depends entirely on what SatNav system you are using and the method you use to add them.
Can you post again with some more details and we can give you a quicker answer Smile
Zondaf
PostPosted: Mon Jul 23, 2007 7:11 pm    Post subject: Reply with quote
Its a Garmin Nuvi 300 using the POI loader software.
PostPosted: Tue Jul 24, 2007 12:04 am    Post subject: Reply with quote
I don't have a Garmin myself, but from what I've read here, you collect all the POI files together on your PC and then upload them all at once using POI Loader.
When you do that, it overwrites everything you had on the unit previously.
PaulB2005
PostPosted: Tue Jul 24, 2007 8:20 am    Post subject: Reply with quote
Andy_P2002 is indeed correct. POILoader is the software you need to use and each time you load POIs with POILoader it'll wipe out all your existing ones, so you need to reload all the POIs in one go each time.
PostPosted: Tue Jul 24, 2007 8:45 am    Post subject: Reply with quote
just thought i;d point out that it ONLY affect custom POI's - ie ones you've added yourself. the inbuilt ones are not affected
