smulroy Occasional Visitor
Posted: Mon Jul 23, 2007 11:29 pm Post subject: Installing POI's for a beginner |
I Have just downloaded the TT POI's from this site but have no clue as to how to install then on my PDA running TT. Can anybody help please? |
Andy_P Pocket GPS Moderator
Posted: Tue Jul 24, 2007 12:18 am Post subject: |
They will download as a "zip" archive (a compressed file). If you have Windows XP just right click on the zip file and select "Extract all".
It should then un-zip to one or more pairs of files which it will store on your PC in the same place as it stored the original zipfile.
For example: PetrolStations.ov2 and PetrolStations.bmp and PostOffices.ov2 and PostOffices.bmp. You should be able to browse and find these files using Windows Explorer
(If you can't see the .ov2 and .bmp part of the names, you need to make some adjustments to Windows Explorer to make them visible (Tools Menu/ Folder Options / View tab. UN-tick "Hide extensions for known file types")
When you've found them, connect up your PDA to the PC however you normally do, and simply copy the .ov2 and .bmp files into your map folder on the PDA (It will be called "Great_Britain-Map" or "Western Europe" or "UK and IE plus major roads of WE" depending on what maps you have.
Disconnect safely when finished, fire up TomTom, go to the preferences menu and select the "Enable/disable POIs" option. You should then be able to switch them on or off individually.
If you want to be alerted to them when you get near, you can do that in the Change Preferences/Manage POIs/Warn when Near POI" menu.
Have a go, and shout if you have any questions. |
Oldboy Pocket GPS Moderator
Posted: Tue Jul 24, 2007 7:03 am Post subject: |
Andy_P2002 wrote: | go to the preferences menu and select the "Enable/disable POIs" option. You should then be able to switch them on or off individually. | If you run with several Enabled, you will find that it will slow down the screen redraw rate and make the movement very jerky.
If you want to be aware of them when traveling, it is much better to do this -
Andy_P2002 wrote: | If you want to be alerted to them when you get near, you can do that in the Change Preferences/Manage POIs/Warn when Near POI" menu. |
_________________ Richard
Posted: Tue Jul 24, 2007 10:56 am Post subject: |
Thanks, Richard. I forgot this can be an issue on PDAs. |
