Pocket GPS World :: View topic - Brodit active mount.
ali
PostPosted: Sat Jan 31, 2004 3:13 pm    Post subject: Brodit active mount. Reply with quote
Just recieved a Brodit active hardwire mount from Handnav.
1.Question is what size fuse should be used when hard wiring the mount?
2.Whats everyone preferred option, permanately live or wired into the
ignition?
Thanks,
Ali
PostPosted: Fri Feb 06, 2004 12:53 pm    Post subject: Reply with quote
I have the same mount for my 2210. I used a 5A fuse and have wired into the accessory socket feed which is also fuse protected and igntion controlled.
Unless you have a need to provide a constant powered feed it is always best practice to wire through an igntion controlled supply Thumbs Up
