Pocket GPS World :: View topic - How to use the POIs to start with?
pedram
PostPosted: Fri Jul 06, 2007 12:09 am    Post subject: How to use the POIs to start with? Reply with quote
I downloaded some of the POIs, but what do i do from there? should i just put the files in the download folder? I tried that, but my TomTom doesn't recognize them.
JockTamsonsBairn
PostPosted: Fri Jul 06, 2007 1:10 am    Post subject: Reply with quote
Copy the OV2s into the map folder. There is a maximum of 39 on v5 & 100 on v6.
Jock
RQ
PostPosted: Fri Jul 06, 2007 6:08 am    Post subject: Reply with quote
And for every file ending with .OV2 there is a corresponding .BMP that also has to be copied into the folder containing your map.
RQ
TT1v3 6.560 1713 UK&NI 660.1199
TTG700 6.520 1387 MoWE 660.1219
Daggers
PostPosted: Fri Jul 06, 2007 9:39 am    Post subject: Reply with quote
Don't forget to open the downloaded .zip file on your computer first, so that you can see the .ov2 & .bmp files in order to copy them as mentioned above.
PostPosted: Fri Jul 06, 2007 1:20 pm    Post subject: Reply with quote
If you are still unsure as to exactly what to do please have a read of the set-up guide Here it was written around a 910 device but shows you the entire process from downloading to configuring the camera warnings - just ignore the warning set-up and the Text To speech part, if you are installing POI's other than Speed Cameras the process is identical - Mike
