jmbillings Occasional Visitor
Joined: 12/10/2002 19:02:52 Posts: 12 Location: United Kingdom
Posted: Tue Feb 17, 2004 10:38 pm Post subject: Where to get a Serial Cable in the UK? |
I need a replacement serial pigtail for my Ipaq 3760. I originally got one from the states, but there must be somewhere nearer! Note, I don't want a serial sync cable or similar as they have a "plug" end, and I need a "socket" end so I can plug my GPS serial cable / vag-com into it... i.e. it needs the "computer" serial connector as opposed to the "accessory"!
Ta |
lbendlin Pocket GPS Staff
Posted: Tue Feb 17, 2004 11:20 pm Post subject: |
You need a cable that has a "female" DB9 adapter. Where do you want to plug it in? Maybe it is cheaper for you to solder one yourself? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Tue Feb 17, 2004 11:43 pm Post subject: |
Thanks for the reply- I need to plug it into my ipaq, so it's whatever the propietry plug is called... Anyways, after a bit more Googling I found one at pc-mobile.net, prod. code PQSM
Cheers,
James |
Pc-Mobile Frequent Visitor
Joined: 26/10/2002 10:38:36 Posts: 789 Location: Hong Kong
Posted: Wed Feb 18, 2004 5:03 pm Post subject: |
jmbillings wrote: | Thanks for the reply- I need to plug it into my ipaq, so it's whatever the propietry plug is called... Anyways, after a bit more Googling I found one at pc-mobile.net, prod. code PQSM
Cheers,
James |
Well done Google!
That's the one! _________________ Pc-Mobile
http://pc-mobile.net/gps.htm |
