thebear555 Occasional Visitor
Posted: Fri Mar 16, 2007 12:22 pm Post subject: garmin i3 |
Thank you in advance. I have a Garmin i3,
software version 3.30
maps from city navigator NT Europe v9
poi from Garmin POI's
and speed camera's from this website
I updated everything last week just before a trip to Devon from Hull
as soon as I set off I noticed the mapping was off, I wasnt driving on the road but to a side of it, and also there is no detail in the maps all my side roads have gone.(map detail set to highest)
luckily I had put in my destination before all went wrong, as now when I try to enter an address the unit gives me the option to select state? with no matches.
so any ideas what i can do to cure these problems?
I notice in other forums people advise to stick to version 2.70 etc but where could I get this from as the garmin website only offers 3.30?
I have tried to re-install v3.30, and the maps but now I'm STUCK.
Thanks again. Dave |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Fri Mar 16, 2007 12:44 pm Post subject: |
Try HERE for earlier versions of the i3 firmware. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21 |
Posted: Fri Mar 16, 2007 3:44 pm Post subject: Update |
Thanks Anita that seems to have fixed it. |
Posted: Fri Mar 16, 2007 4:16 pm Post subject: |
Glad it fixed it - good old 2.7.
The only thing I would like from later versions of the firmware is not having to put a space in the postcode, but it's worth putting up with that to have reliable performance.
Just out of interest, thebear555, do you have one of the original i3s with mapping, POIs etc on a card, or a later model with onboard mapping? V3.3 seems to work OK on newer units, while the older ones perform better on 2.7. _________________ Anita
UK map 1125.12264
Posted: Fri Mar 16, 2007 6:39 pm Post subject: Garmin i3 |
The old type on the card
Another question, Whats the largest Trans flash card the unit can handle?
I noticed you have a 512mb in yours
just out of interest
cheers
Dave |
Posted: Fri Mar 16, 2007 8:20 pm Post subject: Re: Garmin i3 |
thebear555 wrote: | The old type on the card |
Thanks, Dave, that's interesting. It seems that most people with an older unit have problems using the later firmware.
thebear555 wrote: | Another question, Whats the largest Trans flash card the unit can handle?
cheers
Dave |
I believe Garmin recommend the maximum size card is 1GB, which will take all of Western and most of Eastern Europe. My 512MB card takes most of Western Europe, which is more than I'm ever likely to need! _________________ Anita
UK map 1125.12264
sunstrip_steve Regular Visitor
Posted: Fri Mar 16, 2007 9:37 pm Post subject: |
Oddly i have noticed the driving on a parallel road issue with v3.30 (as with v2.90), but only once, now it all seems to work as well as v3.20.
No problems with the address selection though. |
Robin2 Lifetime Member
Posted: Tue Mar 20, 2007 2:45 pm Post subject: |
I don't think it's a Garmin issue. Once on a journey using TomTom on a PDA, I was placed about 200 yards away from my true position, following a parallel path to the actual one. I switched to CoPilot and exactly the same happened. This persisted for about 40 miles until I got home.
I later read that on that evening there had been a very high sporadic E event (disturbance of the ionisation level in one of the ionospheric layers) and concluded that it had in some way interfered with the ephemeris data being downloaded from the satellites
Robin _________________ TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used |
philpugh Lifetime Member
Joined: Dec 28, 2005 Posts: 2003 Location: Antrobus, Cheshire
Posted: Tue Mar 20, 2007 3:01 pm Post subject: |
Robin2 wrote: | I don't think it's a Garmin issue. Once on a journey using TomTom on a PDA, I was placed about 200 yards away from my true position, following a parallel path to the actual one. I switched to CoPilot and exactly the same happened. This persisted for about 40 miles until I got home.
Robin |
It could have been that this event had the effect of delaying the signal very slightly - which would translate to a position error. Interference with (as in altering) any downloaded data should result in it being rejected by the unit as checksums would probably not be correct. _________________ Phil |
Posted: Tue Mar 20, 2007 5:28 pm Post subject: |
Yes, I speculated that the incoming beam could have been very slightly refracted, so that the data did not appear to be corrupted, but the timing was a microsecond or so in error.
The GPS was fine the following day
Satmap Active 10
Posted: Tue Mar 20, 2007 9:23 pm Post subject: |
Strange I spotted this topic today... Something very similar happening today on way home (17:50 - 18:15). I was getting a fix on my nuvi 660 some 50 metres south of where I should have been. Wouldn't lock onto the road unless I was travelling south.
I switched it off and on twice - same problem. Getting full strength sat levels with 9-10 sats locked.
Will have to check if there was any atmospheric issues (aurora etc). _________________ Phil |
