Pocket GPS World :: View topic - Getting rid of unwanted OV files
labeline
PostPosted: Fri Mar 16, 2007 9:09 am    Post subject: Getting rid of unwanted OV files Reply with quote
Apologies to anyone who has seen my similar posts on other forums. I have been told to use the right one!. I am running CoPilot 6 on a Fujitsu L00X PDA. It has the latest ALK update.
The problem. I downloaded the entire safety camera database for all the categories. I made a small mistake and forgot to rename one and mispelt another. Those files now appear in my Custom POI list but I can't get rid of them. The database works fine and I get warned...alot!
I want to get rid of some of the files, for redlights for example. I can find the bitmap files but I cannot find the OV files anywhere, either on the SD card or on My Device. When I search for them I'm told there were none found.I'm told that there should be a folder marked MAPS somewhere but I can't find one. I need to get rid of some of the files as because they are all on there I will not overwrite them unless I download the entire database again and that won't delete the rogue POIs. Any ideas?
nivek22
PostPosted: Fri Mar 16, 2007 1:57 pm    Post subject: Reply with quote
You need to delete your 'ao**' files and add the POIs again.
See these links...
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=44047&highlight=ao
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=48103&highlight=ao
If you still have problems just ask again Smile
labeline
PostPosted: Sat Mar 17, 2007 9:57 am    Post subject: Reply with quote
That did the trick...thanks
22.053 (15 May 24)
