AshleyHinton Occasional Visitor
Joined: Dec 13, 2004 Posts: 30 Location: Oxfordshire UK
Posted: Fri Mar 23, 2007 3:50 pm Post subject: Where is the distance-to-poi warning held? |
Forgive me if this is an FAQ (have done some searching..) but I've just installed the complete speed zoned + Liz voices warnings on my original GO.
Having used the consolodated by type for a few years (ie: Gatso, Mobile, etc) I decided to give the speed zoned ones a try.
I wonder if there was an easier way to set the warn-when-near prefs (ie: single file somewhere) than sit through typing "480 yds" etc into each and every POI on the TomTom?
Thanks,
Ashley _________________ TT GO Original / v7 / 1GB SD - Mac's with 10.6 Snow Leopard - iPhone 3G with CoPilot, Navigon & NDrive - Linux PC with Crunchbang. |
Posted: Fri Mar 23, 2007 4:00 pm Post subject: |
No easy short cut to this one - but once set-up you don't need to do it again, a database update replaces the POI files, but the warnings stay the same, think yourself lucky you don't have a 910 using the Text To Speech - setting that up takes ages - Mike |
Posted: Fri Mar 23, 2007 4:05 pm Post subject: |
Thanks for that info Mike
Indeed I found that once I'd set those prefs for my old cameras I just replaced the files each month without having to set them again - which will be the same if I choose to stick with the speed zoned version.
Have backed up both "versions" of my GO - just in case
Cheers,
