Pocket GPS World :: View topic - Change Nüvi/SP Voices as you did with I3 (Ash10/gcb)
AntiBit
PostPosted: Thu Nov 30, 2006 7:24 pm    Post subject: Change Nüvi/SP Voices as you did with I3 (Ash10/gcb) Reply with quote
Hi, im new here Smile I've studied your old thread of changing the I3-Voices carefully (http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=31721)
What I've tried now to do is to achieve the same for Nüvi/SP Voice files.
Thus, I've programmed a little splitting tool that extracts the VPM, and a
corresponding rebuilder, that generates the VPM again.
Well, the prog works for splitting and rebuilding, the generated output VPM
File is exactly the same as the original Garmin Input Voice-File.
It works also perfectly in the Nüvi, like the original.-
But when I'm changing one of the wav's (I know the format of the wav is
important), the whole Speech gets completely mixed up.
I guess that has to do with the part1.wav, which is the header -
Question:
Regarding the program there is to change the I3-Voices, did you (ash10, maybe you read this) alter the header? Is guess you had to.
Can someone give some info on the header, as we could maybe personalize the Nüvi also a lil' bit?
Hope someones able to help Smile
cguidi
PostPosted: Sat Feb 24, 2007 6:13 pm    Post subject: Reply with quote
Hi, I think nothing to change in the header.
Sure to remake .vpm correctly ?
For nuvi 660T I use wav with 22050 Hz 8 bit coded IMA ADPCM and works fine.
22.052 (08 May 24)
