picdriver Occasional Visitor
Posted: Thu Feb 15, 2007 12:39 am Post subject: ciggy lighter...portable battery solution out there?? |
I drive trucks for a living & a lot of the time the agency will send me on massive multidrops..(with no maps).....of course I get along just fine with the satnav....until I hit a truck with either no..or...knackered 12/24v socket....& the satnav battery don't last the distance.....Just wondered if anyone has come across a battery type gadget which you can plug the satnav (Etc) into??? TIA..Andy |
lbendlin Pocket GPS Staff
Posted: Thu Feb 15, 2007 4:25 am Post subject: |
What charging socket is on your satnav? There are a number of "emergency battery" solutions that can be used to provide external power through round or mini-USB plugs. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Thu Feb 15, 2007 9:39 am Post subject: |
If you are looking for at least a days power (10 hours) or more I would have a look at the automotive boost start units, some of These Boost Starter packs come equipped with a ciggy socket that you can simply plug the existing nav units charger lead in to. I would expect to get around 15 hours use from a full charge powering a Nuvi - Mike |
Posted: Thu Feb 15, 2007 11:27 pm Post subject: |
That'd probably do the trick!..Think I'd look a bit stupid carting that around everytime I started work tho It's probably the solution I've been looking for..but on second thoughts think I'll keep carrying on navigating myself mapwise until I get close to source....(reserving battery)
Thanks Mike & lbendlin for replying....
Oh I don't think it had a charging socket as such anyway lbendlin...only way to charge it is from the cigarette lighter....(I did wire it up to a small mains adaptor once tho & that did the trick..charging-wise) |
Posted: Thu Feb 15, 2007 11:29 pm Post subject: |
Thinking on...the internal battery can't be that big so wiring up to a normal 12v battery might give me a couple more hours.. |
hodgy Occasional Visitor
Posted: Thu Feb 15, 2007 11:36 pm Post subject: |
If you're not using a power connector and connecting directly to a battery you need to be careful as (I'm sure someone can confirm exact figures) most units run on about 5V input (the in-car charging cable contains a step down transformer I believe) so wiring a 12V battery directly to the power input could fry your unit.
Matt |
Posted: Thu Feb 15, 2007 11:55 pm Post subject: |
Yeah you're probably right...(the connector handles the 24 volts from larger vehicles no probs)....it's not direct to the unit I'd wire it tho..but thru the lighter plug (connector) itself....it's what I did when I charged it via a 12v transformer.....thanks for the warning all the same hodgy..cheers...Andy. |
JohnGray Regular Visitor
Posted: Fri Feb 16, 2007 8:42 pm Post subject: |
Have you thought of buying a mrdium handful (8? 16?) of high-capacity AA NiMH rechargeable batteries, finding how long they last in use, and changing them at a convenient/appropriate time on your journeys? A chap at eBay running BudPak does 2800 mAh ones, which are the highest capacity I've seen, at £10 including postage for 8. Saves messing around with cables.
I keep these and the sat-nav in a lined Tesco thick plastic container with a clip-on lid.
John |
Posted: Fri Feb 16, 2007 9:01 pm Post subject: |
If you start using lots of high capacity batteries you should consider a dedicated storage holder for them, if they short out, the higher power capacity cells can catch fire - not a nice experiance - have a look at one of These to keep them safe, they only cost a few quid! - Mike |
Jamas Regular Visitor
Joined: Mar 02, 2006 Posts: 76 Location: Toulouse-France
Posted: Sun Feb 18, 2007 9:46 pm Post subject: Re: ciggy lighter...portable battery solution out there?? |
picdriver wrote: | I.....Just wondered if anyone has come across a battery type gadget which you can plug the satnav (Etc) into??? TIA..Andy |
I managed to build such power supply for few £
Easy to do in one hour max. All you need is:
- one battery holder with a switch that you will remove to put the usb plug.
- one usb plug (female to sold on PCB)
- one usb to mini usb cable.
- 4 AA NimMh batteries
Jamas _________________ SP i3 S/W 2.9-> 2.7 City Navigator V8 NT+ |
mars.1 Lifetime Member
Posted: Mon Feb 19, 2007 11:22 am Post subject: |
You could also use low settings on your device when using batteries for journey's, so they last a lot longer. If you set brightness to 1 and volume at 2, it saves battery power. |
