Pocket GPS World :: View topic - MMI files
MMI files
theripper
PostPosted: Thu May 10, 2007 1:04 am    Post subject: MMI files Reply with quote
Can you have 2 MMI files on a PDA and have full use of the search facility
TIA
theripper
theripper
PostPosted: Thu May 10, 2007 11:26 am    Post subject: Reply with quote
To expand on my previous post(it was quite late)
I have MM2004 with Landranger area 6 and A-Z London & central London all with MMI files. If I can get A-Z MMI search to work then area 6 is not recognised and if I get area 6 regognised then the A-Z is not seen is there any way I can get all 3 MMI files to be recognised on my PDA?
theripper
AllyCat
PostPosted: Thu May 10, 2007 10:27 pm    Post subject: Reply with quote
After MM v5.0.6 there is (or can be) a .mmi file attached to each map (same filename with .mmi extension, in the same folder as the map). Before that, you could only have a single .mmi file in the same folder as the MM .exe file.
The MM 2004 OS maps won't work in v5, but the A-Z might. You can install both MM 2004 and v5 (and the European Edition!) on the same PC and PDA, so that might be a solution.
Alternatively, the best that I can suggest is to keep the individual .mmi files in different folders and copy the appropriate one into the program's folder as required.
Cheers, Alan.
Garmin GPS72H/76/60/45, Etrex H, Mapsource v6.5.
Acer N50,HP114,Loox N560,Dell x50,CF/SD cards to 4/32GB.
RoyalTek,Holux236,Navman B10 & Copilot(Globalsat) BT GPS,TomTom5/6.
Memory Map (v5.4.2 & v5.1.3 OS & Euro), GPS gate,OSGPSconverter.
Mortiki_UK
PostPosted: Mon May 14, 2007 3:59 pm    Post subject: Reply with quote
AllyCat wrote:
That would be the only way to do this with MM2004 as far as I am aware. The MM2004 and MMV5 workaround works very well tho
Cheers, Alan.
Garmin Etrex H
Memory-Map V5 5.2.7
22.051 (01 May 24)
