Chris_UK Occasional Visitor
Posted: Thu Feb 01, 2007 1:29 am Post subject: SPECS Cameras |
How do you know when you are in the specs camera zone? with road angel it beeps for the whole section, what happens with the pgpsworld warnings? |
Andy_P Pocket GPS Moderator
Posted: Thu Feb 01, 2007 2:17 am Post subject: |
You only get bleeps (or voice warnings as you pass each camera.
The POI systems only know about "points in space" not areas or zones, unfortunately. |
Posted: Thu Feb 01, 2007 10:31 pm Post subject: |
So the first beep you get will be the beginning of the SPECS range. Thanks |
classy56 Frequent Visitor
Posted: Thu Feb 01, 2007 10:52 pm Post subject: |
No, it warns you of where the camera is, so it depends on what distance settings you used to inform you of an approaching camera. _________________ Tomtom Go730T
App 8.300
Map v815.2003
To old to die young. |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Fri Feb 02, 2007 12:08 am Post subject: Re: SPECS Cameras |
Chris_UK wrote: | How do you know when you are in the specs camera zone? with road angel it beeps for the whole section, what happens with the pgpsworld warnings? |
It depends on the software.
Most programs just give a standard warning that you are about to pass a camera.
I think there are programs like POI Warner or CheckPOInt (or something) that will start measuring your speed when you pass the first camera and warn you if your AVERAGE speed exceeds the limit while you are betwen the two cameras. Not sure how well it works though... _________________ Gone fishing! |
djkav Occasional Visitor
Posted: Thu Feb 08, 2007 11:48 am Post subject: Re: SPECS Cameras |
The whole section is the SPECS zone. The 1st camera logs u on to the SPECS system. The very last camera logs u off the SPECs system.
You speed is tracked by the SPECs cameras between the start and end points. An average is then worked out.
I don't know if anyone knows. But 1 SPECs camera is only legally allowed to scan 1 lane.
What this means is that if a 3 lane motorway only has 1 SPECs camera on it for the whole section. You enter the zone in the nearside lane (slow) and you leave the zone in the outside lane (fast), then the SPECs system can't detect you.
To scan all 3 lanes, there has to be 3 SPECs cameras next to each other.
Same as if you only see 2 SPECs cameras, this means that only 2 lanes are being scanned. |
swing Pocket GPS Verifier
Joined: Nov 04, 2003 Posts: 2225 Location: Bedfordshire, UK
Posted: Thu Feb 08, 2007 12:27 pm Post subject: Re: SPECS Cameras |
djkav wrote: | You enter the zone in the nearside lane (slow) and you leave the zone in the outside lane (fast), then the SPECs system can't detect you. | I think the system will still detect you - it's simply that the approval for use as a speed camera system only tested you entering and leaving the SPECS zone on a single camera system - you may well still get prosecuted, and you would have to argue why the evidence would be inadmissible.
Quote: | Same as if you only see 2 SPECs cameras, this means that only 2 lanes are being scanned. | Of course, you can't tell which 2 lanes are covered... _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
trevor.dowle Lifetime Member
Posted: Thu Feb 08, 2007 12:39 pm Post subject: Re: SPECS Cameras |
With the ogg files I have installed I get the following warning:
"Warning average speed zone. Speed limit 50 (or whatever) miles per hour."
This is repeated for the duration of being in the area, and is much better than the abrupt:
"Specs" warnining that comes I had with the PGPS data.chk file _________________ Regards
Trev Dowle
TomTom 730 T |
Posted: Thu Feb 08, 2007 12:52 pm Post subject: Re: SPECS Cameras |
trevor.dowle wrote: | Chris_UK wrote: | How do you know when you are in the specs camera zone? with road angel it beeps for the whole section, what happens with the pgpsworld warnings? |
"Specs" warning that comes I had that comes with the PGPS data.chk file |
Update as I cant edit:
The ogg files I use can be found here:
http://www.tomtomsatnav.info/realvoice.html
The ogg files are at the bottom of the page. I think I use the Liz Whittaker files, but may be the Vickie Archer files _________________ Regards
Trev Dowle
TomTom 730 T |
Posted: Thu Feb 08, 2007 1:06 pm Post subject: |
How do you get the ogg file to repeat throughout the zone?
It only gets triggered when you pass a POI point (i.e. a camera position) |
Posted: Thu Feb 08, 2007 1:36 pm Post subject: |
Andy_P2002 wrote: | How do you get the ogg file to repeat throughout the zone?
Don't ask me. I installed the ogg files from Rays TomTom site, and that the way it works now. The wording for the other files is slightly different too, ie:
Warning gatso ahead. Speed limit 50 miles per hour.
Better than 'Gatso 50' don't you think?
However as a speculative answer to your question: I suspect that the phrase is triggered according to the warning distance that has been setup for Specs cameras, and then triggered everytime that the warning distance to the next camera is reached. There is no final warning, but it is obvious when the restricted area is left anyway. _________________ Regards
Trev Dowle
TomTom 730 T |
philpugh Lifetime Member
Joined: Dec 28, 2005 Posts: 2003 Location: Antrobus, Cheshire
Posted: Thu Feb 08, 2007 6:45 pm Post subject: |
Could be something to do with the spacing between the specs cameras, and how you set up the warnings - it could sound like 'continual' warnings. _________________ Phil |
Posted: Fri Feb 09, 2007 10:45 am Post subject: |
I think that must be it.. |
