Pocket GPS World :: View topic - poi loader keeps crashing!!!!
dumpsta
PostPosted: Fri Dec 15, 2006 3:14 pm    Post subject: poi loader keeps crashing!!!! Reply with quote
hi everybody
i have the garmin i3 and have download the camera database from here and the poi loader however when i got to put the bloody things on it keeps crashing. I get to the stage where it asks you if you want to do it manually or express then after i select either and it goes to transfer it dies
someone please help!!!
PaulB2005
PostPosted: Fri Dec 15, 2006 5:48 pm    Post subject: Reply with quote
When you say crashing what EXACTLY happens? "Crashing" tells us nothing! Error messages? How long do you leave it for?
If it just freezes then mine does the same - wait a bit and it'll finish. The transfer stage doesn't take too long - you'll see "Transfering Data" on the i3 screen when it does the transfer. However converting the data does take time and that's what the freeze is.
dumpsta
PostPosted: Fri Dec 15, 2006 6:22 pm    Post subject: Reply with quote
ok i'll give it another go. i have left it about 2 mins before is that long enough? when i do ctrl alt del to shut it down it says that its not responding as well. It just sits there with an egg timer and nothing on the screen of the i3
cheers for the help i really appriciate it Wink
PaulB2005
PostPosted: Fri Dec 15, 2006 6:25 pm    Post subject: Reply with quote
1) Shut down any other programs you don't need. Esp those running at the bottom right of the screen.
2) I'm not sure how long it'll take because it depends on your PCs speed. Mine takes a few minutes but then i also convert mine with Ash10s utility which significantly increases the files size. So maybe leave it up to 5 minutes without doing anything.
